SOURCE: Hi, What is the magneto gap (in mm) for a 30cc
.010" to .012" will normally work just fine.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Testimonial: "Thank you."
SOURCE: how do you change the string feeder on a ryobi gas
If your machine is a "bump feed" there should be a knob on the bottom of the string feed.....this is a LEFT HAND thread, so turn it clock wise and it should pop free and unscrew....re-string your cartridge and replace it tightening the knob counterclockwise until it stops....that should do it !!!... ;-D
SOURCE: Ryobi 30cc trimmer won't run. Difficult to start, hard to keep ru
chnge the plug for the best you can get then depending on the mix petrol oil mix u could cahnge that ie if its 50:1 go down to 40:1 or visa versa if that doesnt work bin it and get a sthil or an ehco
SOURCE: I have a Ryobi 30cc
A good starting point for the Hi and Low speed jets is about 1 and one/half turns OUT from a lightly seated (all the way turned in) position, Never overtighten these as the tips can be damaged. This setting should enable it to start and if one jet had a spring on it, the other one should have one also. Maybe state carburetor/model #'s in another post?
SOURCE: I have a 2 year
Either the pull starter is not pulling or you are not getting compression. To check you need to check the spark plug is still snug. If so, remove the plug and put a drinking straw in the hole to touch the piston. Slowly pull the starter to see if the piston is moving. If the piston is moving and the plug was snug then you are losing compression somewhere, like a head gasket. If not moving then the problem most likely is in the starter, and disassembly required to investigate.
If really helpful, please rate.
