Question about Asko 24 in. D3112 Free-Standing Dishwasher
Overfill Protection tripped on ASKO D3112 dishwasher
The overfill protection tripped on my ASKO D3112 dishwasher. I fixed the problem and have dried out the inside of the dishwasher above and below the filters. The pump continues to run. I have trouble accessing the overfill protection pan underneath due to a kick board. How big is the overfill protection pan? Will it really dry out on its own? I understand that this pan is what is keeping the overfill pump running.
Posted by AndyBhelp on
  • 2 more comments
  • eamherstpat Dec 10, 2007
    my dishwasher retained water probably due to the filter not being cleaned. I have cleaned it out, and bailed the water. When I hit start, only the pump runs...I believe the dishwasher still feels that the water level is too high. Can you help? ASKO 1805SS 13 yrs old
  • Anonymous Jan 02, 2008
    my asko
  • jane9820 Mar 28, 2008
    I have the same problem......I'm going to try the recommendations below and see if I can fix it.
    When I called for service, ASKO said this was not a warranty-covered service call and I could fix the problem myself. They said they would send instructions. Haven't received them yet.
  • Anonymous Nov 29, 2008
    The motor is running after the overfill protection is tripped. How do I fix the trip. Is there a trip switch?
Anonymous
  • 42 Answers
Remove the front toe kick. you should have 6 torx screws. four in the top 2 in the front. your float switch will be in the front center .the float is a piece of styrofoam - the float many times is what you find jammed up making the unit believe it has water in the base
Posted on Dec 21, 2008
Timon Gr?nlund
  • 126 Answers
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Posted on Jan 24, 2008
Anonymous
There is a chance that after the overflow the microswitch monitoring the float has jammed or is broken. This can happen if the overflow was very high.
This switch may be visible in the front of the unit, should be black/brown square with a red contact button underneath. If you're handy with electronics you might be able to remove it and put in an alternate, but in general you're better off just calling the service guy.
If the bottom is dry and it's still not working (ie. pumping all the time) this is probably the cause.
Posted on Jan 30, 2008
F2 overfill. how to reset?
Welcome to FixYa.
Based on your description "f2 overfill. how to reset?" It is likely nothing very serious.
The "F2" with Asko dishwashers means the control is indicating an overfill has been detected...but I gather you know that based on your post.
Whether the unit has actually overfilled or not remains to be seen, but to reset it is fairly simple...if nothing else is at fault.
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. If water is present, with the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base.
By way of removing the water from the overfill basin should "reset" the unit. If the unit works fine after resetting the power/breaker it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump.
Try this and let me know what you find and I`ll assist you in moving forward if necessary.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Nov 15, 2010 | Asko D1776 Stainless Steel Built-in...
A E4 comes up water seems to be in bottom and there does not seem to be a drying mode...
E4 is overfill protection error . If that happens on drain, then it is a drain problem.
Try first tripping circuit breaker and dry water in the tub using a sponge.
Check the drain well and the filter.
Ensure drain hose at the back is not kinked.
Access pump hose , undo it and look for blockage.
Check the water level device. This is usually a float switch, on some model you also have a pressure switch.
Dec 02, 2009 | EuroTech Dishwashers
Drain motor runs all the time. flashing "glass" light , (overfill switch tripped ) but drain system now clear. How to reset. I am 5 hours (return trip) by car to nearest city.
used a (new, clean) plumber's helper to force air through the drain system. The pumping action removed the water from the sensor and back in business.
Oct 31, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
ASKO 1385 not filling after overfill protection was turned on
If when turned on the dishwasher sounds like it is running the drain pump, and does this in any cycle setting, it is possible that the drain pan below the unit has filled with water. Check this post for more details.
Jun 27, 2009 | Asko 1385 Dishwasher
Kenmore Elite Dishwasher - leaks from Overfill Protection Float
I had the same problem, but mine leaked every time. I have a kenmore ultra wash dishwasher no. 665.15762. I took the bottom rotating sprayer off and found that the plastic piece under the sprayer had a few loose screws and the rubber gasket, under that piece, had blown out at the corner facing the overfill protection float. I took out all the screws and re-mounted the gasket in place and put all the screws back and tightened them. It solved the problem. I hope that this helps others.
Nov 11, 2008 | Asko 24 in. D3250 Built-in Dishwasher
ASKO Overfill protection tripped
Dec 31, 2007 | Asko 24 in. D3120 Dishwasher
Dishwasher not filling
There is a new part that replaces the Overfill Pressure Switch part number 8058474. It is now part number 8071024 available from ASKO part sellers. The hose inlet on the new part has what looks like a blockage. It actually "dampens" the effect of the pressure sent through the small hose attached. The old part does not have this "damper" This pressure switch works in conjunction with the flood protection switch in the bottom pan of the dishwasher.
See my rant at
http://www.fixya.com/support/t216284-asko_dishwasher_1475_indicates_high
Nov 06, 2007 | Asko 1385 Dishwasher
Asko 1796 F2 problem
It sound like you have a blocked or a malfunction pump. Remove the pump from the machine and check whether you have a clogged inside the pump or in one of the pipes connected to it. In case all is clean, you should replace the pump.. Good luck !
Aug 27, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Overfill protection tripping
Is there water in the drip pan? My asko developed a leaky inlet solenoid, which would fill the drip pan eventually causing a failure. If the water evaporated, the washer would run. Normally, there should be no water in the drip pan.
May 01, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Ok, heres what you have to do. Remove the lower toe kick and then remove the panel behind that to gain entry to the lower portion of the dishwasher wher the guts are. You will also have to pull out the little brackets that hold the toe kick and all the screws will be t-15 or t-20 torx (little star shaped bits) Once you have all the panels out of the way, you will find water in the bottom of the tray there tripping the overflow switch. Remove the water with a wet vac or towel or something and the drain pump will stop running. If you can't or don't want to do all this, then just let the dishwasher sit for a few days or so and eventually the water will just evaporate and everything will work normally. Hope This Helps!
Nov 24, 2006 | Asko 24 in. D3112 Free-Standing Dishwasher
Asko 24 in. D3112 Free-Standing Dishwasher Logo
2,024 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Marvin
Marvin
MARLON KELLER
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
