Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Can I repair a dial on Bosch front load washer or do I have to replace the entire panel
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: Bosch front load needs new gasket
i think you mean the (door seal), and yes they can be replaced and at little cost and little effort, with out knowing what model your machine is i cant give you an accurate price quote but should be able to pick one up for for next to nothing if you look around. happy to give instructions on how to replace the old one if needed.
Posted on Feb 22, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: How do you replace the
Tilt the m/c back and remove the clamp securing the seal to the front of the cabinet, double the seal back inside the washer door opening, and then pull the retaining spring off the inside of the door seal which is fitted in a groove at the back of the seal.
Refit the new seal starting at the topmake sure the seal is fittef the right way up, drainage holes to the bottom.
Work the seal on all the way round the drum, and then roll the spring into the groove at the back of the seal and work it round all the way round the seal, you will find it easier if you have someone to help hold the spring in place..
Refit the seal round the front of the cabinet,and refit clamp at front.
Plz rate this solution.
Thanks.
Posted on Dec 19, 2008
Joe Hogan
  • 10865 Answers
SOURCE: can i stack the Bosch front load washer with a
There is no stack kit to do what you propose. That said, you may be able to construct a compartment on top of one unit to accept the other.
Posted on Aug 02, 2009
Anonymous
  • 23 Answers
SOURCE: putting on spring loaded wire seal ring on a bosch washer
You have to make sure that the spring part is towards the bottom of the front. If you look closely at the washer at the bottom you will see a groove. That groove is where that spring will need to end up otherwise the whole thing will keep poping off.
how I install is I use a 90 degree pick tool. I work the edge of the seal with the metal ring and making sure it lines up with the groove. once there is tension on the spring I streatch it with the 90 degree pick tool and continue to work the rest of the gasket around. Once you get that completed I push down on the spring to make sure that it is in there. If it is not it takes one door opening to make it fall all apart and you have to start over.
Posted on Aug 13, 2009
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: WFMC 3200 Front Load Washer: how do i unlock door? bosch washer was just deliv...
Hi, welcome to fixya. The emergency latch release is behind the small round panel below the main tub door. **Unplug the washer or turn off the breaker before attempting any suggestion given here please** To open the access door ( small round panel ) you'll require a small round needle shaped object or really narrow screwdriver. Put it in the small hole in the panel push in slightly and turn to about 6 o'clock...clockwise that is The small round cover should now come off and expose the pump with the string going through a hook on the pump housing. Be very careful as the edges are very sharp. A string will be threaded through the pump housing and you just need to pull it to open the main door. Let me know how you make out and also if you require further assistance with this problem. If you don't require further assistance and this indeed was helpful to you, please allow a moment to rate this solution I've given accordingly. Thank you for visiting "fixya" today and good luck. Macmarkus :)
Posted on May 22, 2010
Testing the control panel for damage on a front load washer
How to Diagnose Washing Machine Control and Program ...
? 9:08
https://www.youtube.com/watch?v=QYPqpjLV7s4
Nov 11, 2013 - Uploaded by eSpares
I have a bosch front loading washer that's doesn't have code board. .... there's a clicking behind the front ...
[PDF]GE Front Load Washer - Atech Appliance Repair Service ...
www.atechappliancetechnician.com/GE_Washer_FL_WBVH6240__WC...
Louisville, Kentucky 40225. 31-9135. GE Front Load. Washer. WBVH6240. WCVH6260 ... damage. The man u fac tur er or seller cannot be responsible for the ..... Service Test Mode . .... accessible on the control panel's 7-segment display.
Jan 05, 2016 | Washing Machines
Remove panels on Bosch washer
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Washer-Parts/Model-WFMC6400UC01/1794/0153200?searchedModel=WFMC6400UC&blt=
schematic of your machine...should help show the easiest way to take the panels off, by providing a map of clips and screws involved. also repairclinic.com or apdepot.com both have repair help videos that show the process.
Jul 02, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Logixx WFR2868GB Control Panel broken, dial and display panel, can it be fixed / replace?
I would expect it should be available but you could try checking with spares suppliers to make certain. It might take some time ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number and possibly other information such as the serial number.
Good luck,
John C
Mar 31, 2011 | Bosch Logixx WFR 2867 Front Load Washer
How do I replace the boot on my bosch WFMC6600UC washer? It has a tear and is leaking.
Very hard to replace boot, entire machine has to come apart. 2nd it takes experience to replace a boot, 3rd the boot will cost 150.00 to 250.00.
have a tech do it
Dec 19, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
I have a 3200 and the drum bearing is noisey so i want to change it out. where can i get parts and how doese the drum come out. what kind of warranty comes with these washers. thanks
The bearing cannot be changed without replacing the entire drum. The drum can be obtained at Sears Part central for half what other appliance stores charge The front seal should be replaced as well, The replacement is fairly straightforward if you are still repairing this machine I can provide you with some hints.
Nov 15, 2010 | Bosch WFMC 3200 Front Load Washer
I need help replacing the front door gasket and seal
Bosch WFMC3200 Front Load Washer replacing the front door gasket and seal.
This video will show you how to change a door seal on this Bosch front loader washing machine .
we have all
bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 12, 2010 | Bosch WFMC 3200 Front Load Washer
Danby DT4229 Top Load washer. the washing mecahism
HI. If the timer dial dose not advance, this will indicate that the timer motor has failed. Generally, this will require you to have this damaged timer mechanism replaced, asap. Unfortunately, these mechanisms are not designed to be repaired. The entire device must be replaced, if possible.
Jan 19, 2010 | Danby DTT420 Top Load Washer
My bosch classix 1200 fl wont spin or drain
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Plug off the wall first. Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes (at terminal end of motor), if they are any shorter than 1 cm replace brushes.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Oct 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Washing machine malfunction
The latch might be an issue . Move the dial on pump mode . Try activate the door lock with a screw driver move it to the right and should activate the machine. If that works then the latch is the issue and can easily be repaired by removing the door.
Aug 09, 2008 | Bosch Classixx WFL 2462 Front Load Washer
Bosch WFMC 3200 Front Load Washer needs to replace
door gasket.
This video will show you how to change a door seal or gasket on this Bosch front loader washing machine and also where to buy parts!
we have all bosch repairs in our channel.
Feb 22, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
Top Bosch Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
