Question about Hotpoint Ultima WF865 Front Load Washer
What is fault code 343 - Hotpoint Ultima WF865 Front Load Washer
Xerox 7345 009 343 error code
Check out the Xerox.com website for more upto date information.
.Good luck.
Oct 20, 2014 | Xerox WorkCenter Office Equipment &...
Error Code - 9-343 on Doc 12
it seems you have problem in sensor ...........
change the FD interlock......
Oct 23, 2008 | Xerox DocuColor 12 Printer
Xerox error code 10-343
010-343 not reset code hav
Feb 19, 2014 | Xerox DocuColor 12 Printer
Error code 9 343
Error code 9 343 - Xerox DocuColor 12 Printer
Jan 08, 2014 | Xerox DocuColor 12 Printer
The fan works until the oven starts heating up, oven is putting out a code F11
From the tech sheet:
Fault
Code Description Component to Troubleshoot/Replace
F1-1 Oven temperature above 650° F (343° C) in bake mode. Ohm sensor and harness (see "Oven Sensor" chart).
If OK, change control.
This may be due to your fan failing or a problem with the control board. We rebuild these controls at fixyourboard.com.
Aug 14, 2010 | Jenn-Air JES9800AAS Electric Kitchen Range
Error code 9-343
all 9-xxx codes are xerographic problems,such as toner,drum,developer or auto density.install or replace one or the other.
Jun 30, 2008 | Xerox DocuColor 12 Color Copier
I got a Error code 9-343
any 9 -xxx code is related to the xerographic area of the machine NOT the fuser area- you don't mention the model number so I can't be specific, but try the Drum/CRU/toner area, make sure you haven't dislodged anything (modules, plugs, sockets etc.)
May 08, 2008 | Xerox DocuColor 12 Color Copier
Error code 9-343 for Ducocolor 12
That is a contact failure on the BTR roller. It is the larger black roller inside the left side door. It may just have a dirty contact, or may need to be replaced. But for some reason the machine is not seeing good contact to that roller.
Mar 21, 2008 | Xerox DocuColor 12 Printer
Error code ##343
We have just attempted to install an Cannon imageclass mp360 and the error message "check printer ##343" is displayed.
Can you please help.
May 14, 2007 | Canon SmartBase MP360 All-In-One InkJet...
Hotpoint Ultima WF865 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
James Hehling
James Hehling
Level 1 Expert
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
