Question about Sony Cyber-Shot DSC-P32 Digital Camera
Wont stay on
Camera green light comes on then off/.top light and middle green light by eye hole
ive changed batt...wats wrong.......
Posted by teflon40cal on
  • 4 more comments
  • cihrle Dec 10, 2007
    I have the same problem occurring. In addition, I've noted that if the camera is in the mode where pictures can be viewed, there is no problem with the camera staying on. However once the camera is placed into picture-taking mode, the shutter automatically makes a closing noise and the power is interrupted.
    Can anyone help?
  • Anonymous Dec 19, 2007
    I am having the same problem since I sent it in for the repair to the screen. Any ideas? I've chatted with a SONY rep who suggested resetting and taking the batteries out for a little while then putting them back in. Neither worked. Very disappointing.
  • Jevo Jan 22, 2008
    I also have the excact same problem it is very annoying because I've tried everything i can think of and nothing has WORKED very annoying indeed
  • Anonymous Apr 23, 2008
    when i turn on my camera it stays on for like 3 seconds and then shuts off
  • Anonymous May 21, 2008
    camera turns off soon as it turns off
  • roz5 Dec 27, 2008
    New batteries work, but, even if I've only taken 3 photos, the camera won't work the next time. It doesn't matter whether the batteries are stored in the camera or separately.
Anonymous
I just contaced Sony support for the exact same problem. If you're able to power the camera on in VIEW mode, open the rubber tab to expose the USB and DC In connections, directly above that there is a small RESET button. Get a paperclip and push and hold the button until the camera resets itself. This fixed my problems, hope it will fix yours!
Posted on Jan 19, 2009
Anonymous
Yes, I too have the same problem with the camera switching off straight away. Help!
Posted on Mar 19, 2008
My night time head lights wont come on. Ive changed multipurpose switch and lights still wont come on. Day time lights run in the day just fine, Earlier when my my lights started going out at night. I...
first thing to do is check all your grounds batt. to engine batt. to body batt. to frame then have someone scan the bcm body controll module that operates the headlights ,int.lights, doorlocks, ect.
Mar 24, 2010 | 1998 GMC Sonoma
Kodak easyshare M893 IS will not stay on. The battery has been charged and replaced, however, when the camera is turned on the green light comes on, the "Kodak EasyShare" screen appears for a second or...
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 23, 2009 | Kodak EasyShare M853 Digital Camera
Camera turns on then off immediately
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
Nov 04, 2009 | Kodak Easyshare M893 Digital Camera
Kodak si xe
Of course it could be the batteries . check with Kodak on their website for tech support
Oct 17, 2017 | Cameras
My 4-wheeler seems to not catch any fire..
get a screwdriver and find your cylinoid. there are two bolts coming out the top. touch both bolts w/ the screwdriver and the key on. it should crank your for wheeler. this is just the way us country boys do it.
Mar 08, 2009 | Sport & Outdoor - Others
My ds will not stay on when i turn it on the green light comes on the 2seconds later goes off it wont charge what can i do x
try going to nintendo .com
go to support they give you something like a test to figure out wats wrong and you can set up a repair
Dec 31, 2008 | Nintendo DS Lite Console
Fe-100 wont come on
use external 4.5v npkia battery. huh. ı have same machine and hate olympus.
Jun 26, 2008 | Olympus FE-100 Digital Camera
Blank view finder fe-190
try switching your camera on in a dark room (do it at night with the curtains closed and the lights off).
if the screen lights up (should still be black or a very dark green),
then the lens or light sensors might not be functioning correctly.
if the screen stays conpletely black, then the actual screen might be damaged.
note- you might need to let your eyes adjust to the darkness before you switch your camera on.
May 22, 2008 | Olympus FE-190 Digital Camera
Wont go on
Are you sure the 'New' battery is of the correct type?
what is the oriniginal Battery- Type and Voltage
What have you replaced it with?
Nov 18, 2007 | Panasonic Lumix DMC-FZ20 Digital Camera
Sony Cyber-Shot DSC-P32 Digital Camera Logo
118 people viewed this question
Top Sony Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Harrie
NOEL
NOEL
Are you a Sony Camera Expert? Answer questions, earn points and help others
