Panasonic KX-TG2357 Cordless Phone Logo
A
Anonymous Posted on Jul 01, 2014
Turn ringer on on a tracphone - Panasonic KX-TG2357 Cordless Phone
How do I turn MUTE off on my tracphone. I do not know which button to push.
their are 100s of different tracphones do online search using make and model for owner / user manual
My ringer is off on my tracphone and it wont let me turn it on
Contact Tracfone customer service on this, but my guess is the phone is defective.
Can I use a tracphone without tracphone?
If both companies use sim cards then "YES" you can!!!
Jan 13, 2016 • Cell Phones
I just bought a 60 minute card with my new tracphone and have just registered it and it says I have 5 minutes left???. I paid 19.99 for 55 minutes. Taking it back and really upset!!!!
Tracphone
Check the phone settings before you connect to Cell network.
eg. Airplane mode. Smartphones start communicating right away when you connect which will eat into your $$$$.
Turn off Internet comms till you track down whats using $$
Feb 26, 2015 • Cell Phones
ring the tracphone customer support line and ask them to port your old tracphone number to your new tracphone
https://www.tracfone.com/faqs/phone_upgrade/PHONE_UPGRADE?lang=en
Customer Care Center at 1-800-867-7183
5helpful
HOW DO I TURN THE RINGER ON. HAND SET READ RINGER OFF
Temporary ringer off While the handset is ringing for an outside call, you can turn the ringer off temporarily by pressing {OFF}.Adjusting the base unit ringer volume Press {^} or {V} repeatedly to select the desired volume.To turn the ringer off, press and hold {v} until the unit beeps 2 times
3helpful
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
1helpful
Model GE 27951 - Unable to Turn Ringer back on
The headset volume is turned to zero. Hit the "menu" key on the headset and it should take you to "ringer setting", hit select for the ringer volume and turn the volume up. Not very intuitive but that should get you going!
42helpful
2answers
Turn the ringer off
To turn off the ringer on my Vtech cordless phones, I have had to turn off the base ringer & all handsets.
Base Ringer:
Press Menu and listen carefully, continue to press menu until you hear "Base Ringer, to change base ringer press change", hit change and it will say "Off", then you must hit the PLAY/STOP button to save your change.
Handset:
Press the program button and use your "up/down" key to cycle until you see the Ringer selection. Press SELECT and then use your "up/down" key(s) to cycle until the OFF selection is see on the handset screen. Press select.
10helpful
3answers
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
