Question about Sharp AR-5316 Advanced Digital Imager Copier
Ir 3300 counter reset - Sharp AR-5316 Advanced Digital Imager Copier
Canon ir 3300 reset copy counter how to reset
http://www.copytechnet.com/forums/canon/4517-how-reset-copy-counter-ir-series.html
Aug 13, 2016 | Canon Ir 3300 Black & White Copier
How do i reset counter series in Canon Copiers
that is pretty hard to do . there is some companies where you can send the counter board and they reset it. but I had no more information about it
May 06, 2016 | Canon Ir 3300 Black & White Copier
How do i reset my canon ir3300 counter?
  • Phone Number
    800-828-4040
  • Talk to a Human
    Press 0 at the first prompt
  • Average Wait: 4 mins - M-F 10AM to 10PM
Dec 08, 2014 | Canon IR 3300 Digital Copier
How to reset counter in Canon Ir 3300 Series
Do you mean the page counter?
If you mean that, sadly, you can't reset that, even if you do a firmware reset, you won't success, you have to change the mainboard, PCB
Hope you found it useful
Aug 05, 2012 | Canon Ir 3300 Black & White Copier
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
How to install canon ir 3300 printer installed ?
First make sure a tech's installed the Canon Network Multi-PDL Printer Kit for the IR3300 (includes network kit and BOOT-ROM).
When you press the counter check button do you see IR3300(IR2200N)? If not then you don't have the printer kit installed.
If you have the print kit installed, the print drivers can be downloaded from the Canon website. You'll need to have your copier on your network.
You could then setup a local printer using a tcp/ip port (assign your copier a static IP address) on your server and then share it on your network.
Nov 02, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Ir 3300
E247 The software counter memory PCB and the software counter
value stored in SRAM are found inconsistent are you try to adjust the machine counter reading? That is Canon security features you cannot adjust counter by replacing soft counter board
Jul 21, 2009 | Xerox C2424 Copier
Myprint totals say zero.
Press the counter check button. What counters do you see. There can be up to 6 different ones I believe. What counter numbers do you see e.g. 101: Total 1
Counters to display can be set using Service Mode. Press Additional Functions > 2,8 > Additional Functions.
Copier > Option > User > COUNTER1,COUNTER2,COUNTER3,COUNTER4,COUNTER5,COUNTER6
Default's are COUNTER1: 101, COUNTER2: 103, COUNTER3: 201, COUNTER4: 203. COUNTER5, COUNTER6 none.
You could try entering those counters.
The counters could have been reset. It is apparently possible but certainly not advisable to do so without permission from Canon.
Jul 13, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Sharp AR-5316 Advanced Digital Imager Copier Logo
146 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
