Question about Tomtom One XL GPS Receiver
Can't connect tom tom to computer
Why wont computer accept tom tom when connected
4 Related Answers
Anonymous
  • 515 Answers
SOURCE: message says connect to computer - I do -
Go to:
http://www.tomtom.com/support/index.php?Language=4&query=home&FID=7394
Follow instructions...
Posted on Apr 11, 2008
bob_computer
Project NOMAD
  • 3153 Answers
SOURCE: tom tom wont work after connecting to the computer
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options.
Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card and re-boot
It should now work
Posted on Sep 17, 2009
bob_computer
Project NOMAD
  • 3153 Answers
SOURCE: my tom tom will not connect to my computer, nor
Get the latest version of TOMTOM HOME
Install it and run the program.
Now with your GPS tunred off connect it to your computer via a short USB lead.
Now switch on the GPS and clikc yes when t asks if you want to connect to a computer.
TTH will now start up and from there you can update the tomtom itself.
Posted on Oct 04, 2009
missriverdal
Tina Davis
SOURCE: Can I charge my tom tom by connecting to my computer?
Can I charge my tom tom on the computer?
Posted on Mar 08, 2011
720 go wont let me download music onto it wont let me operate it on the computer
Have you installed an expansion memory card in the 720? Sometimes it wont let you download music because you have filled up the internal memory. You need to put music on to the separate expansion card. BUT... when connecting to the computer to update map corrections and software, if you have not selected INTERNAL MEMORY when it connects, it won't be able to find the tom tom software, so it will just think you have another external USB hardrive attached. SO... take the expansion card out of the tom tom, then connect the tom tom to the computer in the normal way - Voila, suddenly it now sees the tom tom and you can update software. But do not download any more music to the internal memory. Ultimately you will have to format the EXTERNAL expansion card to clear it of any tom tom software updates, then download ONLY MUSIC to the external card. Do not hit Update My Tom Tom while connected to the external card - only do this when connected to the internal memory.
Nov 18, 2009 | Tomtom GO 720 GPS Receiver
Tom tom wont work after connecting to the computer
Remove the SD card
It should now work
Sep 17, 2009 | Tomtom One XL GPS Receiver
Does not recognise the sd card
This is a common error ans is usually caused by the card not being formatted correctly
A card reader/writer on you PC is the best option
If you can plug the card in somewhere other than into the Tom Tom.
Even a card reader attached to the PC vai a USB cable will work
The computer will see the tomtom as a USB drive that can be accessed like a flash drive.
You need to format it either as "FAT or "FAT16" using the reader
In either my computer or windows explorer right click on the card (propably listed as removable drive)
Select FORMAT and use one of the FAT options above.
Plug your tomtom into the pc but don't run the tomtom home software
If the tom tom asks if you want to connect to computer say yes
Now Simply copy all of the files on your tomtom to the new card.
Once you finish doing the copy, you should be able to insert the card
If you need to add any maps voices etc then disconnect the tomtom from the pc and start the tomtom home software, then connect the tom tom to the pc.
Many tom toms will accept up o a 4gb card (but not micro versions)
Aug 21, 2009 | Tomtom ONE XL GPS
Tom Tom 910 connection
send it back its nacked.demand they repair or replace its a common fault they are aware of point them here if they argue dont accept fob offs or their **** service these units are a waste of time there is no easy fix like new mounts or bungs etc
Jan 16, 2009 | Tomtom GO 910
Tom tom one xl wont accept SD card with map on
If you have TomTom that have the slot for SD card, then it should accepted the SD card. The instruction for how to use the SD card is simple, but it is hidden in the TomTom Home, that's why it's difficult to find it. Below are the instruction how to use the SD card.
1. Format the SD card (FAT32) and do not stick the SD in the slot yet
2. Run Backup (connect TomTom device to computer)
3. Disconnect TomTom from computer and turn off
4. Slide the SD into the slot and connect TomTom back to computer (choose "yes")
5. In the TomTom Home menu, Choosen Backup & Restore >>> and choosen Restore
TomTom Home will add all applications to the SD card. So the internal memory still have the applications and the SD card also had the same applications. Everytime you slide the card in, TomTom will automatic detect and use it as its primary storage, if it not detect, you can go to the device menu and pick the device to connect to.
Whenver you take the SD card out, then TomTom will use its internal memory.
Hope this helpful
Apr 24, 2008 | Tomtom One Europe v2 GPS Receiver
No response from touch screen after reset
Hook the Tomtom using the USB cable to your computer. You should see the Tomtom drive under My Computer as a drive letter.
Backup all data from the Tomtom to a folder on your computer. Now select the Tomtom drive and right click, select properties, select tools, and then Check now. Allow the computer to fix any problems with the Tomtom drive. Once this is completed. Remove the USB cable and do a reset. Now turn on your Tomtom and it should work.
Dec 23, 2007 | Tomtom GO 910 GPS Receiver
Tom tom 300
"My tom tom wonts switch on. I have reset it and still it comes on with a boom boom noise and shows the 2 hands on the screen. It also shows the loading bar at the bottom, but then it just freezes and nothing happens. can anyone help please ASAP"
Sound as though your Map data card is corrupt. Remove the SD card and check it with your computer using a card reader. Backup the SD card onto your computer. You can run either chkdsk or go to the drive letter under 'My Computer' right click and select properties, then tools, then check now. You can also try starting the Tomtom with the SD card out of the unit. It should show a picture of the Tomtom with a 'X'. You can also try copying the data on the SD card to another SD card.
Sep 12, 2007 | Tomtom GO 300 GPS Receiver
Tomtom One XL GPS Receiver Logo
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
