Question about Electrical Supplies
Generac troubleshooting my generac 14kw generator engine runs why doesn*t it produce electricity
Posted by Tim Barker on
scottny4
  • 4 Answers
Assuming the generator circuit breaker is on, depending on the model it could be the voltage regulator or the slip ring brushes or both. If it's a portable it could be a capacitor problem.
Posted on Jul 31, 2016
5 Related Answers
John McKinney
  • 42 Answers
SOURCE: wiring diagram for Generac engine on standby generator
here is a wiring diagram for that engine:
Posted on Mar 13, 2009
mamicheddy
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
Anonymous
  • 10 Answers
SOURCE: I have a 17kw generac generator that will run
I have the 18KW model and was told that most alarms relate to a low battery. Make sure the battery charger in the Transfer Switch is properly feeding the battery or hook up a mobil battery charger to the battery and see if the alarm goes away. Good Luck.
Posted on Oct 12, 2009
Anonymous
  • 244 Answers
SOURCE: generator runs, but produces no power
If it's still under warranty take it back to the retailer and tell them it quit working - don't offer any other information.
If you must fix the E/G yourself - On the generator there's a cover on the back; take the cover off so that the back of the windings are exposed. You should see 4 to 6 diodes mounted to the rotor and stator...those diodes are most likely burned out because of temperature failure, due to overload. You have to take them out to isolate them...they should read .6 Ohms one way; reverse the leads and they slhould read about 1.2 Ohms. If there shorted you'll read 0 Ohms and open infinety.
Anyway, replace those diodes and you should re-establish your field winding voltage which develops you A/C output.
Good Luck,
Mike...
Posted on Nov 24, 2009
thesnooper
  • 342 Answers
SOURCE: Wolf 800 generator. Engine will run but very electrical power is
is the engine running at the correct speed
3000 rpm to produce 50hz
3600 rpm to produce 60hz
Posted on Apr 04, 2010
Generac 14kw Propane generator won't start, just buzzes and displays cranking then RPM sensor loss.
if its not cranking clean your battery terminals and check the charge level. also check battery water levels
Jul 14, 2018 | Generac Electrical Supplies
Generac 14kw, overspeed fault
thers a problem with the stepper motor that controls engine speed according to generacs manuals. if you dont have one i suggest if you plan to repair it yourself get one . also join ziller electrics online forum for help
Nov 18, 2017 | Generac Electrical Supplies
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    Trying to find oil filter that can be found locally from car part supply store.
    take the old filter along to the spares shop and see if they can match it up
    I suspect that the same filter will fit both engines
    if you want to get technical, use a verniers to measure the thread hole diameter, a thread gauge to get the thread pitch, and the outside diameter of the oil seal
    by going to oil filters manufacturers on line and researching their catalogues you will find pages of filters with dimensions that will match you filter
    I would rather just go and buy a genuine filter from a mower shop or kohler dealer as there may be a generic filter already listed.
    May 05, 2015 | Generac Electrical Supplies
    Generac generator remote start
    si tiene transfer automatico solo poner un swicht en hilo 1N para cortar senal de entrada al generador del utility power que sensa la presencia de voltage en caso de falta arranca el generador en forma de prueba
    Dec 19, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
    No power output from my generac 5000 power plus.
    sounds like you need to "flash the field". This means you've lost you excitation voltage for the generator to produce electricity. In most cases you need to get a 9volt battery and connect it to 2 & 6 inside the generator. They are Blue & Red wires, but they are not the only blue & red ones there. The generator should be running and the battery should only be connected for about 5 seconds. This is very dangerous because of all the high voltage and democrats.
    Apr 09, 2009 | Generac 100 Amp 120/240-Volt Transfer...
    20KW Guardian Generac does not produce 12 volts to run engine
    The problem is that the printed circuit board inside the generator draws a little current from the battery even when the generator is not running. Over the course of a few days this can make the battery weak enough to be unable to get recharged by the built in running charger which results in not enough power to run the electronic governor on the generator. Usually the spark plugs will work even with a fairly low battery.
    Most of the Generac generators come with a built in trickle charger that runs off of the transfer switch load terminals. If your built in charger isn't doing the job it's either broken or you have the wrong sort of battery installed in the generator.
    Regards,
    Carl
    Jan 11, 2009 | Electrical Supplies
    Electrical Supplies Logo
    303 people viewed this question
    Top Electrical Supplies Experts
    Gene Haynes
    Marvin
    Marvin
    Are you an Electrical Supply Expert? Answer questions, earn points and help others
