Question about magicJack PLUS VOIP Phone Adapter
Macintosh MagicJack Plus software application download please
Stopped working and MagicJack support had me use their uninstall script so now I have no application on the computer and can not open any of the necessary ports 5060 and 5070 via the airport extreme without a computer application - which means I can not use it with the electrical plug and ethernet. HELP
Posted by Veronica Bergman on
Big Poppa Marv
    Sergeant:
  • 302 Answers
Unplug your magic jack and reinstall it into the computer. the software should load
Posted on Jul 03, 2014
1 Related Answer
flekota
Fletcher Wilson
  • 18 Answers
SOURCE: my laptop window 7 OS wont recognize my magicjack plus. what will i do?
make sure its updated?try running it as administrator your firewall or anti virus IP maybe blocking it check all three to see if IP is blocking it use the USB port if it dosn't work trough that your IP is blocking it try reinstalling it follow instruction don't just click next read what it says. it may ask do you want to run as adminnistrator
Posted on Oct 27, 2012
Where can I get the upgrade for Magic Jack on a Windows 7 Vista?
MagicJack installation problems -- here's a great fix! - Forums - CNET
www.cnet.com > Forums > Computer Newbies
CNETI pulled the MagicJack device out and looked for a solution to my CD/DVD drive problem. ... by shep_uk - 8/13/07 12:08 PM In reply to: Windows Vista, Limewire, and CD/DVD drive ... Nothing helped, even the Upgrade was no good. .... to go with a NetBook PC, and installed the bundled Nero 7 Essentials software.
Download MagicJack for XP Vista 7 - Tom & Ruth
www.thomas-n-ruth.com/magicjack-install.html
Free magicJack Download for Windows XP, Vista, and 7. Download free software formagicJack Original, magicJack Plus, and magicJack Go.
Nov 24, 2015 | magicjack.com
Magicjack mac software download
Macintosh software is not available except under the free trial.
Contact customer service as you only need the software and already have the required hardware.
International VoIP Phone Service Customer Care Support magicJack
Jul 01, 2014 | magicjack.com
Script error
On your softphone, please do the following:
1.Click "Menu" on the top right-hand corner
2.Click "Advanced Users"
3.Click "Restart"
If your magicJack is plugged into your modem or router, unplug it from the power source, wait 30 seconds, and plug it back in.
If that does not work:
<Requires some technical understanding. Explanation below. >
Please open port 49152-65535 UDP on ALL firewalls and your router, if you have one. (Router ports can be opened via the web application applicable to your router).
Restart magicJack again by following the steps above.
How to access Web Application for router
1.Start > Run > Type in cmd > Press ENTER
2.A command prompt will open
3.Type ipconfig > press ENTER
4.Make note / write down name of the default gateway and IP address
5.Open your Internet Browser
6.Type in the default gateway IP (Example: 192.168.1.1)
7.Type in Username and Password
8.Find "Port Forwarding" and Forward Port 49152-65535 UDP for the IP address you located earlier.
Apr 20, 2014 | magicjack.com
Uninstalled magicjack now I cannot reinstall
To uninstall your magicJack, please go to control panel and remove it from the list of currently installed programs.
Windows XP
    1. Click Start, click Control Panel, and then double-click Add or Remove Programs.
    2. In the Currently installed programs box, click magicJack, and then click Remove.
    3. If you are prompted to confirm the removal of the program, click Yes.
Windows Vista/Windows 7
    1. Click Start, click Control Panel, click Programs, and click Programs and Features.
    2. In the Currently installed programs box, select magicJack, and then click Uninstall.
To reinstall your magicJack, simply plug it back in and it will automatically reinstall, as long as you have a good internet connection. Check you do not have anti-virus software or a firewall problem.
Put in "error 20" in the search engine on this webpage
What Is Voice Over IP Frequently Asked Questions magicJack and check out the pdf file for settings in this case.
Feb 13, 2014 | magicjack.com Computers & Internet
Need magic Jack plus software download
Magicjack software is stored in the Magicjack module. Plug that module into a USB port on your computer. You should get an onscreen message like: "Install or run program from your media".
Click on "Start Magicjack". That will install the software on your computer.
More information at:
http://www.magicjack.com/how-it-works.html
Jul 29, 2012 | magicJack Two, 2 Magic Jack Plus Voip...
The magicjack loading but minute ago it's not found
Your computer or computer network may block certain software applications in a corporate or work setting.
If your computer has been issued to you by your company and you are having issues loading the magicJack and you also have issues loading other applications or programs, your corporate administrator may have restricted your computer from downloading certain software.
Many large companies, such as IBM and Citibank, place such restrictions on computers before issuing them to their employees.
Please try using your magicJack on a different computer that does not have these restrictions.
In some cases, you might have to disable your firewall during the registration process (less than 2 minutes) and enable it as soon as the registration is complete. This is typical of many other software installations.
Dec 07, 2010 | Computers & Internet
Ereader library won't open
Hi.
If you're using the Windows Operating System, the issue may be caused by the Data Execution Prevention feature in the Windows Operating System or if certain folders used by the Reader Library Software are corrupt. Please click on the below link and select the desired Operating System to get the troubleshooting steps.
If the issue persists, uninstall the Software and restart the Computer.
Next, disable all the active Software's (Firewall, Anti-virus, etc) in the Computer and reinstall the Software.
Also, please ensure to check the "Launch Software" at the end of the installation. This should resolve the issue.
If you're using the Macintosh Computer, uninstall the Software as per the below mentioned steps:
First, click "Go" and then click "Applications" in the Main menu.
Next, in the "Applications" folder, in the right pane, double-click on the "Utilities" folder.
Then, in the "Utilities" folder, double-click "Terminal".Now, in the "Terminal" text window, type "sudo /Library/ebookLibrary/uninstall-ReaderLibrary.sh". There is a required space between sudo and /.
Next, please press "ENTER" on the keyboard. A confirmation message will appear. Please enter your Password or leave blank if you do not have a user account password.
After the Password has been entered or left blank for no password, press ENTER. You will receive the message that the Reader Library Uninstall is finished.
Now, please click "Terminal" and then "Quit Terminal" to exit the Terminal application in the Menu.
Finally, close all other open windows.
Now, restart the Computer and reinstall it.
Note: Ensure that the Reader is not connected to the Computer while performing any of the above mentioned steps for Windows/Macintosh Computer.
Feb 25, 2010 | Sony Reader Touch PRS-600
Uninstall Abode Reader 9.1 before?
I assume you are having issues with Adobe Reader and want to start over. Yes, uninstall the program first and then reinstall.
  1. Exit from all applications.
  2. Uninstall Acrobat.
  3. Search for and delete any .tmp files on your computer.
    1. Delete the following items, if present, from the Documents and Settings/[user profile]/Local Settings/Temp folder:
    2. Folders:
      • _istmp[x].dir
    • Files:
      • _ins[x]._mp
      • _inst32i.ex_
      • _inz[x]._mp
      • _isdel.exe
      • _istmp[x].dir
      • _setup.dll
      • _setup.lib
      • _wutl[x].dll
      • ~ins[x].~mp
        where "[x]" is any number
  • Then reinstall the new Reader program.
    Jan 30, 2010 | Microsoft Internet Explorer 8
    Flip software (Flip Share) quits unexpectedly on my Mac 10.5.6
    HERE IS WHAT FLIP VIDEO SENT FOR A FIX:
    Dear Suzie,
    Thank you for contacting us.
    We will need to try to uninstall and reinstall the FlipShare program on your Macintosh computer. To do this please try the following:
    1. Please open your HD and in the search field type “3ivx”. Drag all 3ivx files into your trash can, and empty it. To uninstall FlipShare on your Mac, please go to MacIntosh HD > Library > Application > Support > Flip Video > FlipShare Uninstaller
    2. Reboot the computer
    If you are receiving the message, "Unable to update database file," when upgrading to FlipShare 5.6, there may be a corrupted file within your existing FlipShare database.
    Please try the following to upgrade to the current version of FlipShare and import your videos into the application.
    1. Copy your entire FlipShare Data folder onto your desktop or another drive
    - the FlipShare Data folder can be found in "Username">Movies>Flip Share Data>
    - ensure that you have copied all of the contents of the FlipShare Data folder and have secured a complete back-up of this file
    2. Delete the FlipShare Data folder from your "Username">Movies>Flip Share Data>
    3. Uninstall FlipShare
    - MacIntosh HD > Library > Application Support > Pure Digital Technologies > FlipShare Uninstaller
    4. Reboot your computer
    5. Click on the link and follow the on-screen instructions to install FlipShare 5.6 onto your computer
    For Macintosh systems (including Snow Leopard): http://download.theflip.com/update.theflip.com/app/fvsw/561/update/Setup_FlipShare.dmg
    6. Once FlipShare 5.6 has fully installed, launch the program
    7. Go to the Help directory and choose "Recover other FlipShare files..."
    8. Click Proceed and select the Videos folder of the drive where you saved your FlipShare Data folder
    - the FlipShare Data recovery tool will import your videos into FlipShare
    Should the issue persist, please do not hesitate to contact us again so we may further troubleshoot.
    Thank you,
    Flip Video Support
    May 05, 2009 | Pure Digital Flip Video Ultra Camcorder
    magicJack PLUS VOIP Phone Adapter Logo
    65 people viewed this question
    Top magicJack Cell Phones Experts
    gaucherre
    Andrew Taylor
    Andrew Taylor
    Are you a magicJack Cell Phone Expert? Answer questions, earn points and help others
