Video Game Consoles & Games Logo
Question about Sony PlayStation Video Game Consoles & Games
How come when i'm using my ps4's internet browser to play facebook games and youtube videos it wont let me and gives me this message "Missing Plugin"
Posted by Matt Gange on
Edward Stotts
    New Friend:
  • 11 Answers
4 Related Answers
Anonymous
SOURCE: dvd playback
hey if its a moded one then u will hve to switch off ur modchip(by pressing reset for 3(approx) seconds)...then onlyu will be able to play dvd movies
Posted on Apr 01, 2008
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: Will play CD's but not DVD's or Games
You have to take the box apart and clean the lens.Ok !
  1. The white plastic gear that moves the laser must make contact with the "motor". A bad contact here can cause disk read errors. Sometimes it looks Ok, but you may need to remove the lens and bend the white gear for good contact.
  2. The two rails on which the lens move must be very slippery - which can be lubricated with cooking or motor oil. Usually the holes where the rail is (on the right side of the lens) are dirty or you have to bore then out slightly, making the holes bigger.
  3. The lens uses little torx screw (black) that move the lens up and down on the rail. Usually the lens is too high and requires adjustment.
  4. Take the lens off these 2 rails and take the black plastic cover off. Turn the lense upside-down and you'll find there are 2 screws (silver, phillips or torx) that you have to remove to take the upper little lens off.
  5. Then you'll see a larger lens that is usually very dirty (this lens is a mirror to light). If that's dirty, it will give a disk read error. You'll have to take the little electric board off that you see on the other side of the big lens-mirror. It's probably dirty too, so clean it. Alcohol should work OK for this task.
  6. The lens bottom has 2 + 2 screws. You move the upper "little" lens up-down-left-right (this may require a special screwdriver)
  7. The motor "rail" that moves the lens must be very clean and oiled and the 2 rails too.
Posted on Jun 07, 2008
Anonymous
  • 14 Answers
SOURCE: I have a ps3 slim 120GB and it keeps freezing up
I WOULD NEVER RECOMMEND SLIMS OF ANYTHING BECAUSE THE COOLER aka AC IS SMALLER AND NOT AS BIG IF U GOT A REGULAR 1 U WOULD HAVE NO PROBLEM
Posted on Feb 11, 2010
Richard T
  • 441 Answers
SOURCE: wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
Posted on May 15, 2010
Wont play youtube
If that is some company's computer you are using to access youtube from work, the company's IT department may have set security policies than prohibit access to Youtube and possibly other social sites. Alternatively, the plugin that plays youtube videos in the browser may be missing.
I have problems watching video's on facebook
that might be that your browser doesn't has a plugin for playing video on it,you need to install adobe flash player to play video on internet browser you can download it here
http://www.adobe.com/support/flashplayer/downloads.html
remember to restart your browser after installing flash player
please let me know if it's working or not and thanks for using fixya
I have been using my PS3 to access the internet and it has being working fine until recently it now wont let me on the internet saying it doesnt have Adobe Flash Player to watch trailers or things like itv...
Try this and if it doesn't work let me know and we will go a different route.
  1. Start your PlayStation 3's web browser. You can do this by navigating to the "Network" category on your PS3's main menu and selecting the "Internet" option.
  2. Point your web browser to a website that uses Flash. YouTube, at www.youtube.com, is a good example.
  3. Let the page load. Depending on your Internet connectio, this could take a few seconds.
  4. Click "OK" when the box reading "Install Missing Plugin" appears on screen. As Flash comes pre-installed on the PS3, this will update you to the latest version of Flash. You will know the update is complete when YouTube videos then begin to load.
1helpful
2answers
A Video plugin is missing. I cant see videos.
Hello, my friend, you can check Leawo Free YouTube Downloader.
You can use it to view online video in its built-in FLV player, and download online video to your computer. It is so helpful.
This is its user guide - http://www.leawo.com/youtube-download/user-guide.html
I cant play youtube videos the message is 'you need to upgrade the flash player'
You need a flash player plugin for your browser.
go to this site>>http://get.adobe.com/flashplayer/
download and install the latest version. You need to restart the browser for flash player to work and play youtube videos.
hope this will help...cheers:)
Video does not open. gives me a update flash message. done iot many times
you might be using a 64 bit operating system and you're trying to play videos from websites like youtube or facebook which would require you having flash player installed in your computer. flash player is currently not compatible with 64 bit browsers. the solution: use internet explorer 32 bit. or download google chrome or firefox and try accessing and playing online videos from there.
1helpful
Sir,when i download youtube video it seems to me this line. http://www.free-codecs.com/download/FFDShow.htm.I could not playing games. I have not able to get solution to download youtube videos or can...
You may want to download the latest version of flash player for your internet browser. As for playing downloaded videos from youtube try this:
http://www.mydigitallife.info/2009/02/22/enable-windows-media-player-to-play-flv-codec-plugin-free-download/
My slim ps2 keeps saying web browser configuration, reading data and just stays that way. Wont play games or DVDs.
you must put internet on the ps 2 and let it run there may be data lost sow just put internet plugin then let it do the work it realy does work
Top Sony Video Game Consoles & Games Experts
Marvin
Marvin
ELECTRICKSUSA
ELECTRICKSUSA
Steven Wander
Steven Wander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
