Question about SVA-USA Computers & Internet
Can i make a 19" sva tft lcd monitor a touch screen
Model-9005w-B
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: damaged power cord
The power supply AC adapter power cord is the same as used for PC power cord, local PC repair shop should have them.
Or you are looking for the AC adapter is 12v 4A power adapter, try Ebay
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 13, 2010
Testimonial: "Thank you very much! Very helpful!"
How do you factory reset this?
under my computer you will find the tab. Be ab solutely sure because you may lose data.
Sep 08, 2013 | Generic 19" sva 9005w-b widescreen lcd...
Model : ev - 1703 C115 ?
What is the problem of your monitor? I will appreciate if you can give details on the problem and i will be glad to suggest solution to the problem, once i have the information.
Take care.
Jun 30, 2010 | SVA-USA SVA 19" LCD TFT MONITOR
Damaged power cord
Jun 13, 2010 | SVA-USA 9005B (Black) Monitor
Monitor blinking off & on rapidly. Just started it out of the blue during use. Turned off computer over night. Still having same problem after re-booting this morning.
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 13, 2010 | SVA-USA SVA 19" LCD TFT MONITOR
Monitor doesnt seem to be getting power i turn the power on the power adapter has the power light on but the monitor lightdoesnt come on
You need to oepn it up and check to see if you do have 12vdc feeding the inverter board, let us know what you see for further help. There are surface mounted fuses (Fx) on the inverter board.
Jan 25, 2010 | SVA-USA SVA 19" LCD TFT MONITOR
Everything is too big on the screen when I get on the internet
Try selecting a much higher resolution from the menu
1650x 1200 should be ok for a 19" or 1260x760 or something within those parameters
Please rate my help++++Thanks for using FIXYA
Oct 20, 2009 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
Installed 19 in tft-lcd monitor on new vista computer, used dvi-d input, screen is flickering
You need to up the refresh rate. Your settings may be slightly different to mine but this is how I get to it:
  1. Right-click on the desktop, select Personalize, Display Settings.
  2. Click Advanced Settings, select Monitor tab.
  3. Change Screen Refresh Rate to the highest number that is available.
Sep 08, 2009 | SVA-USA Computers & Internet
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Computers & Internet Logo
Top SVA-USA Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
