SOURCE: 4.0 Tucomsa engine on a 4 year old troy built tiller
I highly recommend that, that you clean you inti-er fuel sys. than RR your carburetor and clean it vary good, make sure your jet holes are clean too. install a needle and seat kit. install fresh fuel. must be stabulize at all times. good luck let me know. PS change your oil 30W
SOURCE: Troy Bilt Tiller and Pressure Washer
The carbs are plugged. Take the bowl off the carburetor by loosening the nut on the bottom. You'll want to clamp the fuel line before you do this. That nut has a small hole that goes through the nut from side to side, and one that connects them in the center. Use a wire brush to knock all the deposits loose, making sure that the holes are clean and free of obstruction. Put it all back together, and it should run fine.
