Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Gas leak from oven
Hi, when I turn on my oven, I smell gas coming from the oven. Although the oven does start to heat up, the gas smell continues.
Thanks,
Cassandra
Posted by wmcfarl1 on
  • 4 more comments
  • Anonymous Aug 05, 2008
    have a GE gas oven which leaks after the wall source is turned on. It's faint and the stove top burners/ oven work ok. It scares us and we're afraid to leave the gas on or use it. Help
  • bcburrows Mar 20, 2009
    Yesterday I changed the glow plug in my 1989 Magic Chef gas range/ oven. The oven now works perfectly. After I installed it I did however notice a gas odor with all burners off and oven off. When I turn off the main gas line behind the oven there is no more odor. How can I find the leak? Could it be a gasket? How do I access the gasket?
  • Anonymous Mar 21, 2014
    Metallic oven smell doesn't smell like dirty oven
  • Anonymous Mar 27, 2014
    Oven starts heating, then shuts off when it hits around 250 degrees. F-14 comes on panel and then oven shuts off
  • Anonymous Mar 28, 2014
    it is a diplomat but i cant see what number it is.
  • Anonymous Mar 29, 2014
    Smell gas coming from unit. At first the smell came from the one main burner in front, but now gas smell is everywhere from unit. Wondering if it could be the regulator kit or if I should replace something else besides that... Thank you for any information.
Craig Shelton
  • 473 Answers
Sounds like the ignitor is weak and needs to be replaced. How old is the oven and what is the model # from the sticker on oven?
Posted on Nov 07, 2007
We have the smell of gas when the oven is pre-heating
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
May 02, 2010 | Ovens
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Stoves Ovens
Our oven doesn't heat and smells like gas
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 02, 2010 | Maytag Ovens
Oven is slow ot light and has a gas smell when
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 21, 2010 | Kenmore Ovens
Oven doesn't heat up
Hi, Even though your igniter is glowing it's bad..A igniter should glow brillient yellow for it to be able to light the gas...basically whats happening in your case is although the igniter is drawing the correct amps to open the gas valve it is not getting hot enough quick enough to light it..change the igniter and you should be good to go. Good Luck!!! Mike
Aug 17, 2009 | Ovens
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 | Ovens
Strong Foul smell coming from oven only when I turn it on
do you have mice.they will tunnel in the insulation.you know what they do next,well then you heat that up and theres your smell
Dec 31, 2008 | Magic Chef 9122 Gas Single Oven
Gas oven clicks but doesnt ignite
Not getting gas so check gas outlet in the bottom of the oven for clogs , if not clogged the thermostat is bad
Jul 22, 2017 | Ovens
Gas smell at start up
Be sure that the igniter has a good ground. I mean make sure you clean it well. Be sure its fastened well. And of course that it is close enough to burner. Air flow in building can also hinder lighting.
Nov 14, 2007 | Blodgett DFG-100 Gas Single Oven
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
1,125 people viewed this question
Top Jenn-Air Ovens Experts
Nathan Van Boven
Nathan Van Boven
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
