Question about Maytag MSD2456G Side by Side Refrigerator
Where is the defrost timer on a matag mtb2456dew
Warm fridge cold freezer
This usually happens when your Defrost (heater) is not working, Firstly Get your Defrost Timer Checked. If that is the problem then the timer is much easier to be replaced. Depending on the models the Timer prices differ from $10 to $115.
If this is not the issue then Inside the freezer is the Defrost Heater Placed, and you will figure out that this unit is having the problem due to which the channels to pass the Cool air into the Fridge is blocked and not keeping it cool. You will have to check if this Heater can be fixed or replaced. *Again this cost will Differ based on the models*
Mar 18, 2014 | Refrigerators
Matag msd2651kes side
Sounds like you need a new defrost control/timer.
Mar 01, 2014 | Maytag Refrigerators
Refridgerator not cooling. Replaced defrost board. Snapping or popping noise heard underneath or behind.
Defrost coils are bad and burn out board...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 16, 2011 | Maytag Matag 25.6 Cu Ft Side By Side...
MTB2456DEW makes a popping noise every hour or so
thats nothing to worry about,its just the defrost cycle and its drippingwater on the defrost heater and sizzling as it evaporates,this sound is normal
Jan 07, 2010 | Maytag Refrigerators
Freezer is working but main fridge is not getting cold
I want you to look into the back of the freezer and see if you notice ice beginning to stick to the metal panel that has the evaporator fan behind it. Let me know because this is usually the first sign the defrost timer or defrost element and defrost thermostat are not working properly. Sea Breeze
Jul 21, 2009 | Maytag PTB1954GR Top Freezer Refrigerator
Solution for ''my side by side msd2556aew matag refigerator is not keeping the refrigerator cool It has ice build up by the fan in the freezer
your not going through defrost cycle. remove rear panel in freezer and defrost ice. need to verify defrost timer, defrost heater and defrost thermostat. these are the only parts that deal with defrost cycle.
Jun 22, 2009 | Refrigerators
Maytag refrig freezer not working
The defrost coil may be bad. It's real tough to get at, you have to remove the cover over the freezer coils. First make sure it's not just the defrost timer. Check Repairclinic.com for parts and help.
Apr 01, 2009 | Maytag Matag 25.6 Cu Ft Side By Side...
MATAG FRIG PTB2153GR FREEZER DOES NOT GET COLDER THAN 38 DEGREES F
Try turning the defrost timer clockwise until you hear it click. If defrost element and defrost thermostat are working properly, the refrigerator should begin to defrost. The timer is located inside the fresh food compartment behind plastic controls cover and also near the thermistat control.beb686d.jpg .I will be around if you need, just let me know,Sea Breeze
Mar 23, 2009 | Maytag Refrigerators
My refridgerator will not cool , the freezer works , it is a matag double french door style model.
check the defrost system.. evaporator fan, heater, timer and defrost thermostat...
Aug 18, 2008 | Maytag Refrigerators
Maytag MSD2456G Side by Side Refrigerator Logo
73 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Pierre Laplante
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
