Question about BenQ Joybook 5100U Notebook
Gateway touchpad scroll not working - BenQ Joybook 5100U Notebook
1 Related Answer
Anonymous
  • 31 Answers
SOURCE: My touchpad scroll not working
Problem with touchpad driver. Download and install latest driver from the manufacture's website (synaptics, alps...) if you know the driver name.
Else try the software DriverMAX
(downloadable at http://www.innovative-sol.com/drivermax/)
Im using DriverMAX. Its a good software that can automatically detect versions of drivers in our computer and update them if you have internet connection.
Also ensure that in startup programs (RUN>MSCONFIG) the touchpad driver entry is enabled!!
Posted on Oct 26, 2009
Scroll on touchpad not working
Go to touchpad Properties.
Un/Check option to scroll.
Should be fixed.
Feb 27, 2015 | Gateway Nv57h77u Laptop/notebook
Scroll bar on my touchpad/mousepad not working??
Go to Control Panel > Hardware and Sound > Devices and Printers.
Then, right click on the laptop and select mouse settings. Click on touchpad and go to Gestures. Finally, check that scrolling is activated.
Feb 22, 2015 | Gateway NV53A75u 15.6 Laptop X3 2.1GHz 4GB...
My touchpad scroll bar on my Gateway NV57H73u Laptop is not working. The touchpad itself is working though. Can anyone help?
Some laptops/notebooks [weight is the difference between the two], sometimes if you've tapped on the touchpad, it can activate or deactivate features. However, if you're running windows 8, be careful with window updates since they have been known to screw up your PC.....
Feb 05, 2014 | Gateway NV57H73u Laptop Computer With...
Gateway NV52L06u how do you turn scroll lock off?
Device settings > Synaptics touchpad > settings > virtual scrolling > untick the "enable vertical scrolling" box.
The "enable horizontal scrolling box should be there too.
Apr 20, 2013 | Gateway NV52L06u A6-4400M 2.7GHz 4GB 500GB...
SCROLL SWITCH NOT WORKING
do you mean the scroll function on the touchpad; have you got the correct touchpad driver installed?
Mar 09, 2012 | Gateway 450ROG Notebook
Is there a way to disable jus the side scroll bar on my gateway laptop touchpad without disabling the mouse itself? on my touchpad if my hand jus gets in front of the touchpad it scrolls and makes my...
yes. its in the control panel under mouse properties. Look for the advanced properties, theres alot of settings you can change there for the touch pad. There might be a link to the program in the start menu too.
May 15, 2011 | Gateway Keyboard/Mouse
Scroll not working
Try going to the Gateway website and downloading updated drivers for your touchpad.
Dec 29, 2008 | BenQ Joybook 5100U Notebook
My scroll on the gateway fx doesn't work
i just went to best buy and thay installed a driver from gateway and wow it works
Oct 30, 2008 | Gateway MT3705 Notebook
Scroll touchpad broken at my gateway T 6321
I guess that some settings with touch pad might have changed.
try accessing the touch pad controls in the control panel.
may be its called synaptics ....
lemme know if it works :)
Aug 06, 2008 | Computers & Internet
BenQ Joybook 5100U Notebook Logo
Top BenQ Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Paul Bade
Marvin
Marvin
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
