Question about Zebra 105SL Thermal Label Printer
Where is the thermal ribbon on a Zebra ZM400 printer?
5 Related Answers
WillBGood
SOURCE: Zebra 105 SE Printing Blank Labels
Seagull Scientific has drivers. Their Zebra driver is recommended by many.
http://www.seagullscientific.com/aspx/drvrmain.aspx
That's the link for their printer drivers page. Go to the bottom and click on 'Download a printer driver'. Then scroll the list to find the one you need.
Posted on Jun 10, 2008
Anonymous
SOURCE: ZM400 printer
Try going through the LCD menu and if it say "Direct Thermal" change it to "Thermal Transfer", Direct Thermal made means, no ribbon required, but it sounds like you do have ribbon in the printer, if so, try my recommendation. If it asks for a password, it's '1234'.
Posted on Apr 24, 2009
Anonymous
  • 21 Answers
SOURCE: my zm400 keeps reverting back to direct thermal
did it stay on direct thermal if you not doing any print job ?
then i assume you the problem is when you printing .In ZEBRA DESIGNER, there's a printing preference that can be set up... i think u selected direct thermal when you print with zebra designer, that's why whenever u start printing, it show RIBBON IN again.
the solution is, Just changed the printing method from zebra designer.
if you aren't using zebra designer, then the problem at your driver. Open Printer & Faxes, then right click your Printer and klik on Printing Preferenced. There u can set up the printing method to Thermal Transfer.
The thing is....... changing the Setting from LCD panel won't change the setting on the driver.
i hope this will help you
Posted on Aug 20, 2009
Raj Pots
  • 16 Answers
SOURCE: Error condition ribbon out in ZM400
In the printer setting-
Change the Print Method from - "Tharmal Transfer to Direct Thermal" and save it permanently
Posted on Sep 08, 2009
Anonymous
  • 4 Answers
SOURCE: keep getting broken ribbon message on zebra P330i printer
Hello, assuming the supplies are Zebra and there is no discernible damage to the ribbon, it could mean that the ribbon sensor on the printer is broken. if your printer is still under warranty you can ship back to Zebra (Illinois) to get it repaired. The zebra website has info on how to return printers for service. Hope this helps.
Posted on Mar 08, 2010
I cant perform anything on my printer because when i turn it on it comes with a ribbon and paper out error.what should i do
please check if you fit the paper and ribbon at correct place (under the crome plate and between the printheard and white roller.
Aug 22, 2014 | Zebra ZM400 Thermal Label Printer -...
Black horizontal line on zm400
check the pressure of the printhead.increase the pressure of the printhead.
its a ribbon friction line.
Dec 28, 2013 | Zebra ZM400 Direct Thermal-Thermal...
Hello, I changed the ribbon. The ribbon and labels
can you adjust the printhead pressure?? if so then do that
Aug 22, 2017 | Zebra ZM400 Thermal Label Printer -...
Will not print onto the label. but can see it on the black ribbon reel.
Perhaps your darkness is set too low, or your labels are not coated to accept thermal transfer printing. Let me know if this helps!
Aug 28, 2011 | Zebra ZM400 Thermal Label Printer -...
I cannot print from my mac to a ZM400 Zebra printer
That is correct, you can try VM Windows. I would get a cheap laptop instead, as it is easier. Hope this helps!
Apr 27, 2011 | Zebra ZM400 Direct Thermal-Thermal...
Have A Zebra Z6M Plus 300dpi printer Z6M00-2006-0000, then purchased a Zebra ZM400 300dpi printer, attempting to print using formats from Z6Mplus, result is a print approx 150 % larger ??? Downloaded...
Print configuration from both printers and compare. Print config- Hold cancel button 10 sec. while power on. Check Resolution parameter. 203dpi=8MM Full , 300dpi=12MM Full. Sounds like perhaps they are different dpi.
Apr 03, 2011 | Zebra ZM400 Thermal Label Printer -...
My zm400 keeps reverting back to direct thermal
Aug 19, 2009 | Zebra 203DPI Printer
Aug 10, 2009 | Zebra 105SL Thermal Label Printer
How to load new labels
http://www.scanonline.com/Online-Store/ZM400-600
Download the ZM400/600 Quick Reference Guide on the right hand side of the page. They have a diagram on how to load labels.
There should also be one inside the printer - printed on the back wall...
Jul 10, 2009 | Zebra ZM400 Direct Thermal-Thermal...
ZM400 printer
Oct 14, 2008 | Zebra 203DPI Printer
Zebra 105SL Thermal Label Printer Logo
93 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
