Question about Oakley Thump MP3 Player
One ear speaker stopped working - Oakley Thump MP3 Player
Hi. I am being faced with a recurrent problem. Again and again, the speaker in the flap stops working. so then i have to put on the speaker and talk. I showed the phone to a mechanic, they changed the ear...
the speaker in the flap stops working. so then i have to put on the speaker and talk.I showed the phone to a mechanic, they changed the ear flap with the ear piece but it worked fine for a few phone calls only.Kindly advice.
33helpful
3answers
5130c-2 ear sound
Hi you should change the speaker because it is faulty thats why you can't hear any sound.
Can't hear call from the ear piece only on speaker
There could be a Three problems. In all cases you have to get it serviced.. Cause no.1_ Your ear speaker has stop functioning. Cause No.2_ There could be a connection loss with ear speaker. Cause No.3_ IC which looks after ear speaker has stop functioning..
Hope this has helped you.. Please rate the answer. Thanks
1helpful
Gateway- built-in laptop Speakers not working
Seems to me the speaker is just plain broken. You'll need a new one, contact your vendor for repairs, or you will have to live with using external speakers/earpieces...
I hope you will get your replacement,
Yannick.
4helpful
No call volume om samsung e250
This because in your handset there will be 2 speakers
1 is loud speaker and 2 nd one is ear piece speaker....
so the loud speaker is working fine ...
There may be some loose contact in the ear piece speaker or the speaker might have got damaged ...
so if you are good at opening then just open your handset and check if there is any loose contact in the ear piece speaker .. is so fit it correctly ..
or you replace the ear piece speaker with the new one ...
if you are not good at opening then just contact the technician ...
he will do it ...
The ear piece speaker is very cheap so no problem .. just buy the ear piece speaker which is compatible to your handset in the shop if you are doing it by your self ...
the technician might take the service charge for this that s all but the ear piece speaker is too much cheap ..
any doubts reply me
i am always here to assist you
thank you
bye ...
Flip up ear speaker stopped working
Sounds like the ear piece connection between the two halves of the phone has been broken. Your "speaker phone" function should still work because the sound comes from the back of the main body of the phone. To the best of my knowledge, this can't be fixed. You will need a new phone. I hope this helps.
Razr speaker problems
Dear sir
my cell phone in comming and out going call speeker doesn't work but my spoker on work voice bad.spoker off feel nothing. i am live in texascity.TX 77590 where close me service center please fix this problam.Thank you.MANI.
Phones ear speaker stopped working?
I guess this is a common problem huh. No worries!
First: Click on your music button and play a song as you would normally do on your phone (make sure your speaker is on during this point).
Second: Click on the speaker button so you can listen to your music through your ear piece (as your music is still playing). If you don't hear your music through your ear piece wait until you hear it. It shouldn't take more than a minute. (Your music should be playing throughout this whole process)
Follow these steps every time you come across this problem.
If this solution resolved your problem, please leave a comment and a good rate. Thank you!
No sound
I've had my speakers for about a year now and all of a sudden they just stopped playing music/sound. I can still hear that 'fuzz' if I put either speaker up to my ear. Everything lights up properly but nothing is being played.
Razr - no ear speaker sound
check for dust on the tip of speaker points.clean the points on circut board also .check speaker with multi meter if speaker damage,change it.
Oakley Thump MP3 Player Logo
Top Oakley Audio Players & Recorders Experts
Harrie
Vinho Xie
Vinho Xie
Are you an Oakley Audio Player and Recorder Expert? Answer questions, earn points and help others
