SOURCE: lcd projector projects images upside down???
if you go through the projectors setup menu you will find the option to invert / flip and rotate image adjust as required
REgards Al "alastech"
SOURCE: How do I flip the image on an Epson EX50 for
go into the menu, image adjustment, and chose ceiling.
SOURCE: how do i flip the image on my epson projector when
go to:
-menu
-extended
-projection
-front ceiling
happy projecting
SOURCE: My Epson Powerlite 5350 has a ghost image. Any
I've got the same problem on two Epson EMP7300.
I believe (from reading about other projectors) that the ghost image can be adjusted with RS232 codes.
Does anyone know how to do this?
SOURCE: my projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
