I have a relatively new Taylor 7405 and the screen keeps showing "ErrH" and blinking on and off. I've replaced the batteries, left batteries out for days and I still get the same error. I can't take it back because i didn't keep the receipt thinking it was working properly.
SOURCE: ERROR message
This link allows you to troubleshoot directly with the company...I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
SOURCE: We have a Taylor 7542 Bathroom Scale. I need to
I called Taylor; the Model 7542 take a 3v CR2032 battery available at Walgreen's, CVS, WalMart, etc.
SOURCE: I put the new battery in my Taylor 7004 V1812 and the screen rem
Check and see if you put the battery in right. Make sure the rough part is facing bottom.If this doesn't work your battery may be bad.
SOURCE: Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
