Syntax-Brillian Olevia 242TFHD 42 in. LCD TV Logo
A
Anonymous Posted on Jun 30, 2014
How do I mount. - Syntax-Brillian Olevia 242TFHD 42 in. LCD TV
1helpful
Iam no mech but is it hard 2 change the motor n transmission mounts in a 96 ford thunderbird 3.8 engine if it is whats the going price 2 do so i dont get taken
It is fairly easy to do if you have a lift, but it is possible to do on the ground with a jack and jack stands. You will need to be able to unbolt both sides of the mount and support the engine with the jack while you replace the mounts. If you download the autozone app to a smart pone or tablet it will give you a repair estimate calculator,
Frontmotor mount torque
Rear mount mounting bolts: 43 Ft-lbs
Side engine mount bracket mounting nuts: 40 ft-lbs
Transmission mount bracket mounting bolt/nuts: 40 ft-lbs
*Front mount mounting bolt: 47 ft-lbs*
2helpful
2answers
The brake lights that we need 2 fix r on the trunk /hood.( what holds the spoiler if there was 1) looked all over. either cant find or see or get 2 it?
This is right out of the manual. Hope it is what you are looking for. Cobra. :-) Lamp, Rear Hi-Mount Removal
  1. Slide rear hi-mount lamp cover (13A656) away from back window glass (42006) and remove rear hi-mount lamp cover.
  1. Remove one screw retaining rear hi-mount lamp (13A613).
  1. Lift edge of rear hi-mount lamp and pull away from back window glass.
Installation
  1. Follow removal procedure in reverse order.
  1. Slide rear hi-mount lamp cover onto rear hi-mount lamp to engage retainers.
    Hi-Mount Rear Lamp
    Item Part Number Description 1 921 Bulb 2 56929-S2 Screw 3 13A613 Rear Hi-Mount Lamp 4 13A656 Rear Hi-Mount Lamp Cover 5 15A442 Rear Hi-Mount Lamp Wiring
1helpful
What accessories to use for what?
You would use your windshield mount and suction it to the plastic horse shoe mount as a dash mount, and there is tons of other mounting options that you may wish to look at.
You can find many different TomTom mouting solutions such as vent mount, viser mount, cup holder mount, vehicle specific mount, windshield mount along with dash mount options at www.autonavdirect.com or www.autonav2000.com.
Good Luck
I have an Olevia 332 b11 LCD tv. I want to mount
There should be at least 4 mounting holes (VESA mount), and they should be used.
13helpful
Need the correct torque specs for 2004 silverado 1500 calipers
  • Tighten the 2 brake caliper mounting bolts to 108 Nm (80 ft. lbs.) . Caliper Mounting Bracket to Knuckle, Front (15 series) 175 Nm (129 ft. lbs.) Caliper Mounting Bracket to Knuckle, Front (25/35 series) 300 Nm (221 ft. lbs.) Brake Caliper Mounting Bolt Rear (15 series) 42 Nm (31 ft. lbs.) Brake Caliper Mounting Bolt Rear (25/35 series) 108 Nm (80 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JC5/JH5) 200 Nm (148 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JH6) 165 Nm (122 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JH7) 300 Nm (221 ft. lbs.) Caliper Mounting Bracket Bolt Rear (NYS) 200 Nm (148 ft. lbs.)
    hope this helps
  • 0helpful
    2answers
    Can thris protron tv be mounted on a wall?
    it can be mounted, they sell a universal hanging kit, you will see 4 holes in the back of the tv, thats where you put the screws for the mount
    Top Syntax Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
     Grubhead
    Grubhead
    Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
