Question about Canon imageCLASS MF6590 Copier
SOURCE: How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Posted on Jan 05, 2009
SOURCE: remove a paper jam under the fuser unit on a canon
Hello sir; I believe You have to detacth finisher unit then open the side door to reach the fusing unit see is there have jamming paper over there ,the paper under the fusing unit just open front door turn the knob clockwise on the fusing unit paper will coming out.
Posted on Aug 18, 2009
Feb 03, 2013 | Canon Office Equipment & Supplies
Apr 29, 2011 | Office Equipment & Supplies
Oct 23, 2010 | Canon imageCLASS MF6590 Copier
Sep 23, 2010 | Canon imageCLASS MF6590 Copier
Apr 27, 2010 | Canon imageCLASS MF6590 Copier
Dec 05, 2009 | Canon imageCLASS MF6590 Copier
Oct 02, 2009 | Canon imageCLASS MF6590 Copier
Sep 22, 2009 | Canon ImageClass MF5770 Laser Copier...
51 people viewed this question
