Question about Uniden BC350C Base Scanner
How can I get codes for the BC 140? - Uniden BC350C Base Scanner
3 Suggested Answers
Anonymous
SOURCE:
BillB-SA
Bill Buchsbaum
  • 2761 Answers
SOURCE: manual for Bearcat Scanner BC 140 10 channel
I couldn't locate a manual for your oldie, but it's fairly simple to operate.
  1. Turn the scanner ON.
  2. Press "Manual" to stop scanning. Use the keyboard to choose the channel you want to enter your first frequency into. If you want channel 2, press the number 2 on the keyboard and then "Manual" again. If you want channel 12, press the 1 and then the 2 and then "Manual" again.
  3. Enter the desired frequency, including the decimal point. For instance, if the frequency is 555.789, enter 5, 5, 5 and then the dot button, then 7, 8 and 9. Then press "Enter" to complete the setup.
  4. Use the "Manual" button to move to the next channel to enter the next frequency. Continue this process until you have all frequencies entered.
  5. Complete your entries and then press "Scan." Set the squelch by turning the "Squelch" knob all the way up and backing off until you hear no static.
  6. Lock out a channel that is annoying you by pressing the "Lockout" button. If you want to listen to the channel again, simply select "Manual," find the channel by entering it on the keypad and then hit "Lockout" again
For a comprehensive database of active frequencies in your area, visit
www.RadioReference.com
Posted on Dec 12, 2009
BillB-SA
Bill Buchsbaum
  • 2761 Answers
SOURCE: wisconsin codes: dont have one for 10 channel
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
BillB
Posted on Feb 02, 2010
Scanner static
the police have turned on squelch .... ask them to turn it off
Mar 29, 2014 | Radio Communications
98 F250 heat gauge in red, engine slows down, coolant level steady, rad cool. Had new head gaskets and head planed last Sept. new fan & water pump. What can be wrong?
I am a little confused here, you say the temperature gage is in the red but the engine is only at 140-160? Is that Fahrenheit?
Jul 25, 2017 | Ford Cars & Trucks
I have an old Kodak 760 carousel projector with 140 slide rotary. Can I get replacement rotary slide holders?
You can buy new & used Slide Trays for Kodak Slide Projectors from: www.vinevalleyimaging.com They have amazing connections with slide projector users!!
Oct 15, 2010 | Kodak BC-4401 Slide Projector
I have a Bearcat BC 140 scanner that has 2 issues
You have a power supply problem. Lag on start up with low audio. Send it to the factory for repair.
May 01, 2010 | Uniden Radio Communications
Wisconsin codes: dont have one for 10 channel scanner undiden bc 140
BillB
Feb 01, 2010 | Uniden BC248CLT Base Scanner
Manual for Bearcat Scanner BC 140 10 channel
Nov 06, 2009 | Uniden BC248CLT Base Scanner
Bearcat 140 scanner.It will scan but will not pick up any signals,even witha tower antenna? none at all and not myweather channels also.
If you are good with electronics, go to www.mods.dk. They have an alignment manual for the Bearcat 140 series that also includes troubleshooting advice and schematics.
Use the manual for the Bearcat 145XL. It is virtually the same radio as the 140.
The link to the file is:
http://www.mods.dk/downloadmanual.php?RefFil=BC-145XL_Alignment.zip&radio=
Sep 28, 2009 | Uniden BC244CLT Base Scanner
How to program a bc 560xlt bearcat scanner. Thanks, Les. [email protected]
hello there: here is a link for you that will help out ok
best regards mike
How to Program a Uniden Bearcat Scanner BC 140 | eHow.com How to Program a Uniden Bearcat Scanner BC 140. Programming a Uniden Bearcat ... How to Program a Bearcat 5 Scanner. How to Program a BC 560XLT Scanner ...
www.ehow.com/how_5009391_program-uniden-bearcat-scanner-bc.html - 57k -
Aug 24, 2009 | Office Equipment & Supplies
Uniden BC350C Base Scanner Logo
247 people viewed this question
Top Uniden Radio Communications Experts
Jason
Robert McClure
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
