Question about Philips Magnavox Learning Universal Remote
How do I program a philips universal remote to control my magnavox dvd player?
5 Related Answers
Anonymous
SOURCE: Philips Magnanox Universal Remote CL034
I found this website and it has the codes for everything for your universal remote. Good Luck.
http://www.universal-remote.net/philipsmagnavox.html
Posted on Feb 14, 2008
guest10
SOURCE: philips universal remote control cl034
hey i tried this and it worked. hold code search till the light stays lit(it may take a couple of secs ) then after its lit press tv and then keep pressing channel up or down till the channel on your tv changes when does press mute to save the code. also the power button will work to during code search , but i use channel because if you accidentally skip your code you can go back the other way. you might need to take out the batteries then re-insert to reset any previous codes. hope this works for you guys as well.
Posted on Jun 06, 2008
Anonymous
SOURCE: codes
I need to program my LG TV to my Apex dvd player. Can someone help me?
Posted on Aug 11, 2008
mixelcores
mixelcores
  • 10 Answers
SOURCE: Remote Control Code for Magnavox mdv-430 dvd player
Yes, a Philips replacement remote should be an excellent choice for your Magnavox DVD player, since they are sister companies. I am using the inexpensive Philips URC US2-PH5DSS and it works well. Your Philips remote will come with a page with all manufacturer codes listed by the type of device. Or you can visit the Philips URC code lookup website at www.urc.philips.com.
The codes listed for Magnavox DVD players are:
0441, 0442, 0447, 0599, 0799, 0699, 0247, 0193, 0093, 0598 You'll have to try them one at a time to see which works best for your player's functions.
Posted on Jan 21, 2009
Anonymous
SOURCE: Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Posted on Oct 19, 2009
Need code to program magnavox mwd200f dvd playe with univeral remote
go to internet search...universal remote control codes for magnavox. one of the web sites has the answer.
Jul 02, 2012 | Philips Magnavox/Mwd200f Dvd Player No...
I'm having problems programing my Philips RC19041006/01 remote that came with a Philips 15pf9936/37 15" LCD TV to work on a Magnavox MDV21001F7 DVD Player
Unfortunately, you will not be able to program your TV remote for the DVD Player. The MDV2100F7 was produced in 2010. Your Philips TV was has a manual with a copywrite date of 2003. Other documentation on the Philips site is from 2004 and 2006. (I am assuming that the MDV2100F7 is your model since no MDV21001F7 is listed at Magnavox or Funai (which made the unit).)
The codes in a universal remote control are only for devices released 6 months or more before the remote was programmed. A DVD player released 4 years later is likely to have a different set of control frequencies.
You need a newer remote or control everything with separate remotes. I wish that I had better news for you.
(The manual for the Philips TV is available from the Philips product site. For the Magnavox DVD player documentation, see the Magnavox (http://www.magnavox.com ) site or the Funai support site (http://www.funai.com/us ). At Funai, search for the model number but leave off the brand. They make units for a number of brands.)
Oct 04, 2011 | Philips Rc1904100601 Remote Control
Magnavox dvd player and universal remote need code please
have rca universal emote need codes to progam magnavox dvd player please help thanks
Mar 17, 2009 | Philips Televison & Video
Jan 21, 2009 | Philips Magnavox Learning Universal Remote
Need a code for a VCR/DVD player for my universal remote
Magnavox VCR. The Phillips universal remote lists the following codes:0330, 0430, 0534, 0324, 0224, 0124, 0247, 0230, 0125, 0093, 0598, 0830. Doesn't seem they have much control of which code gets used on which model. Start in the middle and work both ways to the ends. Make sure to post back which one you find that works.
Jan 15, 2009 | Philips Magnavox Learning Universal Remote
Philips Magnavox Learning Universal Remote Logo
123 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
