Question about Sena SMH5-FM Bluetooth Headset Wired Mic - Dual Pack Wired Microphone
My sena smh5 mic does not fix good on preglued female velcro how could i fix-it easily
Posted by Michel Champigny on
Thomas Smithbrother
    Top Expert:
  • 3,698 Answers
Add more velcro. Can be found at any hobby or sewing center.
Posted on Jul 01, 2014
How can I keep the velcro from coming undone on the strap?
One thing to try before you get to replacing velcro is to take a stiff brush and remove the extraneous matter from the velcro straps. There is stuff like cat hair, human skin and dirt that gets caught in there and it weakens the velcro grip.
Mar 12, 2016 | Clothing Accessories
My iPhone 5 will not pair with a Bluetooth device
First switch off and switch on,both phone and Sena,switch on BT on the phone.Switch on BT on Sena.Give search on both the devices.As soon the BTs are detected give connect.It will work.
Oct 04, 2014 | Apple iPhone Cell Phones
Are all A/C to USB power converters the same? i.e. Apple & Sena products use same voltage & Wattage output from the A/C component?
No not all USB chargers or cords are the same. Notable differences are the current that they will supply. That said I think the Apple USB adapter should work fine as a charger for your bluetooth.
Feb 21, 2018 | Sena Radio Communications
Audio connections and video seem to be making bad contacts. The mics work intermittently and video intermittently works when wires are jiggled. Using cordless mics with reciever. When reciever is connected...
Sounds like you have a bad set of jacks. This typically occurs when the female ports on an electronic device begin to fail. The inside of these audio and video ports have a contact pin that the male connector comes in contact with when inserted into the female port. A little adjustment of the female pin connection will usually do the trick. You may also want to check the solder joints or connections.Sometimes they begin to break and lose contact.
Hope this was helpful. Good luck.
Apr 03, 2010 | JVC XL-MV303 CD Player
Cobra gtl 148 seems to have no power til i push on mic connecter.
cobra 148 shows no wattage output on external meter but does show good modulation.
Dec 08, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Does the SE Mini use a standard cable or is there a special cable needed for use in an amp or computer?
you'll need an xlr (male) to xlr (female) to use the microphone with 48v phantom power (from a preamp). phantom power dosnt work with an xlr to jack, only both xlr.
Apr 22, 2008 | SE Electronics SE MINI Microphone
Need of codes....
Hi I hope this will help http://www.dvcentral.org/tricks.html Tricks 4 XLR ins: Get the Canon MA-300 adapter and get yourself 4 XLR inputs. Perfect for a couple of wireless lavs, a boom, and another mic. Sure, it's less data for the audio channels, but it's plenty for voice recording. Sure, you can't digitize audio 3&4 easily, but it is possible, and it's just so darn useful to have four audio channels in the field. (Also, you can easily mount the wireless lav receivers right on the back of the camera.) Using the Canon on-camera mic via an XLR input: Say you're using a single boom mic, inputting via XLR 1. You've got XLR 2 doing nothing, and the on-camera mic doing nothing. Seems a waste. Well, all you need to do is adapt the on-camera mic to input through XLR 2. A short female-mini-to-male-XLR adapter will do for the audio signal, but the mic needs power. Simple, just get a short micro-mini extender cable, plug one end on to the mic, and the other into where the mic's connector would normally plug, on the camera's handle. Make sure the mic is switched to stereo, and voila, you have a second XLR mic. Monitoring in the field: Though many people told me it couldn't, the XL H1 downconverts to NTSC on the fly during recording, so you can plug a little monitor or deck into the video and audio out jacks and have yourself a video tap. Perfect for the director who wants to see what's going on through the camera. I used a little DV camera, and recorded it all so we could have a playback tape if needed. Very useful. (Note that the output NTSC is anamorphic, stretching the 16:9 image over the whole 4:3 frame. A monitor with a 16:9 switch is useful, or something that automatically adapts, such as what I used, a Sony PD-100 DVCAM camera.) Native slow motion: In a 24F project, shoot 30F and use Cinema Tools to slow down the footage to 24fps for a slight slow motion effect. Use 1/60 shutter speed for a standard look, or 1/30 for a slightly dreamier feel. Good Luck.
Sep 15, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Loose Latch - does not lock
I had the same problem - my fix is simple, cheap and works great - obtain some of those double sided hook and loop (Velcro) straps used to tie cables in a neat bundle - the 3/8" - 1/2" wide version works best, these are approx 4" long and usually black in color - costs approx $2 for a package of 10 straps.
Cut off a piece from one of the straps, approx 1" long and glue this to on side of the neck of the charging base. Glue the reverse side of the remainder of the Velcro strap to the other side of the neck, position it with enough length to go over the top of the push in plug (when closed), at the top of the neck, and cover the full length of the first piece of Velcro glued to the other side of the neck + remember allow some additional length so you can easily grab the end of the long piece to release the Velcro grip and let the plug raise clear of the razor.
When the glue is dry, pull the long end over the top and position it to hold the neck plug completely down, and be retained by the first piece of Velcro on the neck - trim the long piece to length, remember you need a little extra length, to make releasing the Velco grip easier. I just pull on the long end of the Velcro, this closes the plug into the razor and simply push the Velcro together to start the cleaning process - simple and cheap.
Mine has been working for years.
Sep 06, 2007 | Braun Syncro 7526 Electric Shaver
Sena SMH5-FM Bluetooth Headset Wired Mic - Dual Pack Wired Microphone Logo
88 people viewed this question
Top Sena Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Sena Radio Communication Expert? Answer questions, earn points and help others
