Question about EEEKit for Zeki 7 inch TB782B Tablet, Zeki 10 inch TB1082B Tablet, iPad 1/2/3 iPhone 5 Google Nexus 7 Kindle Fire HD, 10-Pack Universal Capacitive Touch Screen Stylus Styli Pen 3-Pack Green Screen Cleaning Cloth
I have had this tablet for a month, gets hot while charging and know it will not chare at all
Posted by nedra piep on
masood ahmad
    Sergeant:
  • 314 Answers
Problem with ic
go to service centre
Posted on Jun 30, 2014
Battery port
Depending on how hot you may be right. It is normal for the battery to heat up when you charge it. I have an RCA tablet that while the charge port (which doubles as the micro USB) fits tight and the battery still heats up to the point where it is hot to the touch but not to hot to hold. If your charging port is broken then the tablet will nont charge at all. If it is loose and not getting good connection then the battery will charge intermittently. Again either of these issues will not cause the battery to get abnormally hot. However, if there is an issue with the battery itself then it may get too hot. If so the charging circuit thermistor should cause the battery to stop charging.
Aug 24, 2016 | Tablets & eReaders
Had this tablet for one day, its showing 50% .. battery, when should I recharge..
There's no harm in keeping it on charge all the time. Unlike older rechargeables, newer Li-ion batteries don't need to be broken in by running them down and then recharging.
Feb 12, 2015 | Tablets & eReaders
Can i safely use my tablet online while its charging?
Yes you can use your tablet online while it is charging. But your tablet might get hot while you are using it on the charger. Some tablet get warm/hot while they are charging and being used at the same time.
Apr 12, 2014 | Computers & Internet
HTC sensation X315e charging problem
Leave it on until all power gone then hold down power button for 30 sec's and the try charging.
Jan 15, 2014 | HTC Tablets & eReaders
Wont charging
Contact Amazon. They will replace if still under warranty.
If not under warranty then it's bad news :(
Dec 22, 2013 | Amazon Kindle Fire HD
Battery charing very slow, can't open tablet - won't turn on when button is pushed
The battery on the Asus does take a very long time to charge (over 12 hours before you use it the first time, then 8 hours or more each time). It takes even longer if you charge it from the USB port in a computer rather than connect it to its dedicated charger, or if you use it while it's charging. If you've already charged it for 8-12 hours, try turning it on by pressing the power button *and holding it down* for a couple of seconds before releasing it. Then, when using the tablet, try keeping it hooked up to the charger when possible, or at least recharge it overnight.
You can check on battery charge by tapping "Settings" at the bottom of the Home screen, then tap "Battery" in the Device category. The % charge will be at the top of the screen. I enjoy my Asus tablet, and it's good for several hours at a time between charges, but you do have to keep it charged up. Good luck!
Dec 18, 2013 | ASUS Transformer Book T100
I HAVE A SANYO CHARGER NC61 WHICH SHOWS TWO GREEN LIGHTS WHEN CHARGING, HOW DO I KNOW WHEN THE BATTERIES ARE CHARGED/
Generally speaking,six hours is enough to charing SANYO Battery with full power ,when it is full it will stop charing automatically.
Feb 09, 2011 | Cameras
EEEKit for Zeki 7 inch TB782B Tablet, Zeki 10 inch TB1082B Tablet, iPad 1/2/3 iPhone 5 Google Nexus 7 Kindle Fire HD, 10-Pack Universal Capacitive Touch Screen Stylus Styli Pen 3-Pack Green Screen Cleaning Cloth Logo
475 people viewed this question
Top EEEKit Computers & Internet Experts
Tom Chichester
Marvin
Marvin
Lawrence Oravetz
Are you an EEEKit Computer and Internet Expert? Answer questions, earn points and help others
