How can i reset to manufacturer setting
In order to reset a phone you can look for the steps depending on the model of your device from this website: How to perform Master Reset Master Clear, but you can follow the steps from your specific phone from here: Linux Java Non Touchscreen Master Reset Master Clear
Posted on Jun 30, 2014
SOURCE: Master Reset
the
OPCODe can master reset the phone. I screwed up my phone by trying to
change the theme and evry time i pressed menu the phone restarted.
However, i found a post on another site that read...
For me, Motokit, PTS, and the reset of the tools could not reset my
phone. Here's how I reset my phone with just the phone keboard.
This will reset all your menus. On my Verizon Razr V3m phone, my
contact and my picture gallery were not affected. (Make sure you key
the command in exactly. 18*1 is Master Clear, and you don't want do to
that.
From your phone, enter this sequence to go into OPCODE mode fairly quickly:
Press CLR then
048263*
This puts you in OPCODE mode, where you can enter special commands. Be CAREFUL here.
Enter a the code for a Master Reset command:
18*0
Press the middle navigation button.
Wait. The screen should show "SUCCESS" after a few seconds.
Push the LEFT soft key (back). You'll be back at the OPCODE screen.
Push the RIGHT soft key (options). Push this button again to select Cancel Entry (the only option).
This gets you out of OPCODE and back to where you started. You might
have to push CLR a few times to clear the number you entered to get
into OPCODE mode.
It was really helpful
Posted on Apr 23, 2009
