Question about Cartoni Photography
Cartoni C40 fluid head
I need to add fluid to the head of my C40 pro tripod. Do you have any manuals or help with this?
Thanks,
Dean
Posted by temecula on
5 Related Answers
Anonymous
  • 121 Answers
SOURCE: Pan control not fluid when tension increased
Sounds like you might have gotten some dirt trapped under there. You might try to loosen it and blow it clean.
Posted on Apr 17, 2007
Anonymous
  • 121 Answers
SOURCE: Problem with solidex tripod
ptolhatley,
If it is a standard professional tripod - they are sold without the head mechanism so you can pick the type and style that best suits your needs,such as for sports, portrait, or commercial photography. Most camera shops can show you samples of the different types. You can go online to get an idea of the range in price (be aware that they are as much as a standard tripod that has a built-in head).
randy320sgi
Posted on Jan 12, 2009
MIke
  • 685 Answers
SOURCE: Fluid head platform is moving before the fluid
Below the head where it attached to the center column is a set of three screws. Back them out a little bit and then tighten the head, then screw those three grub screws back in to lock the head.
Posted on Apr 05, 2010
Testimonial: "Yes. This was the fix. Thank you very much."
MIke
  • 685 Answers
SOURCE: fluid in velebon tripod
I cannot tell you esactly, but it seems to be more of an oil or grease than a liquid.
Posted on Jun 25, 2010
Anonymous
  • 69 Answers
SOURCE: radian pro Gt head broke that holds the scope.
You can still order the plate that attaches the camera/scope to the head from Eagle Optics directly at this link:
http://www.eagleoptics.com/tripod-accessories/vortex/radian-pro-gt-quick-release-plate
Posted on Aug 14, 2010
Testimonial: "Thanks for the info, that's wasn't the part I need, but I think I located the part on the website link you sent."
How should fluid heads be stored?
Alisa: With all 'video tripod heads'...., regardless if the are the original 'true' fluid heads (that actually used a liquid (oil) to achieve 'fluid' type movements) or a modern professional 'fluid' head (that actually uses a clutch mechanism like a cars transmission) or a fluid effect head like the Manfrotto #501HDV (which used nylon discs sandwiching a ball bearing race)...., always store with the pan and tilt mechanisms unlocked!!!! This means the camera platform should be positioned in the 'rest' position (not tilted forward or backwards), also ensure that any counterbalance mechanism is released so as to eliminate strain on the internal mechanisms!!!!
If you remember to do this and don't overload the head..., you will extend the life of your gear significantly
Peter
Nov 12, 2013 | Manfrotto 501HDV Pro Video Head Tripod
I have what was a BOGEN MANFROTTO TRIPOD 3246 WITH 3047 FLUID HEAD PLATE that is discontinued I'm looking for the user manuals.
There really are not user manuals so to speak. If you need service or repair try: http://www.manfrottotripodparts.com/repairs.html If you are looking for more tripod use info try: itripod.com
Apr 03, 2013 | Manfrotto Photography
What fluid do i need in my 3066 tripod
they don't use fluid - maybe some grease in the tilt and pan of the head, but the tripod itself doesn't need any.. you might need an adjustment somewhere... I own 3 of these.
Feb 07, 2013 | Manfrotto Bogen 3068 Tripod With Bogen...
Mike, does my Sunpak PRO 423PX have a reversible head fitting?
There is no point in addressing queries to individuals - none of us are members of staff, merely volunteers who try to help.
You can get a 3/8 to 1/4 adapter at any reputable camera store, or on eBay.
Aug 29, 2017 | Sunpak Photography
Apr 04, 2010 | Bogen Communication Bogen Manfrotto 3046...
Who do I contact to get repair of quick release's on 519 tripod
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I’ve seen.
Jan 18, 2010 | Bogen Communication Bogen / Manfrotto 519...
Velbon DV 7000 replacement parts
Hi I need a locking clip for one of the Velbon Tripod legs any suggestions?
cheers
Wayne
Apr 15, 2009 | Velbon Sherpa DV7000 Tripod
Problem removing head from tripod
Look on the underside of the platform where you screwed on the head. It should have 3 small screws in it. These are tighened and loosened with a jeweler's screwdriver. You may have one screw that is just *barely* tight, so you were able to hand tighten the head until it "locked" into place with the screw. When you loosen each of these screws a few turns the head should come off.
If you can't locate these screws, or you can't remove the head, you will need to take the tripod to a large camera store for assistance. Their rental or repair department can help you remove the head. If you need help locating a large camera store with a rental or repair department in your area, I may be able to help - I would need your location (e.g. city/state/country/zip or postal code).
Dec 31, 2008 | Bogen Communication Bogen Manfrotto Tripod...
Bogen Tripods, changing heads.
I searched around and all I can find is this: http://www.manfrotto.com/Jahia/site/manfrotto/pid/2477
Jul 02, 2007 | Bogen Communication Bogen - Manfrotto...
Apr 16, 2007 | Sunpak Video Pro M Tripod
Photography Logo
71 people viewed this question
Top Cartoni Photography Experts
Marvin
Marvin
Tony Parsons
Tony Parsons
Are you a Cartoni Photography Expert? Answer questions, earn points and help others
