It sounds like you have your gain to high. best way to solve this is by turning the gain way down to - or lowest number , then turn everything on and upto the volume you desire, then slowly up the gain. also avoid using bass boost, I agree it sounds great but it puts strain on the amp and shortens life in the amp. with the bass boost off, you can adjust others (not the gain) to get bass.
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hook up the composite cables that come with the unit. Turn the TV on to the correct input. Turn the PS3 on using the power button on the unit. When you press the button continue holding the button until you hear a second beep....about five seconds. That should set the PS3 back to the factory output. If that corrects the problem you can set the PS3 to use whichever cable you want via the XMB.
There are two possible problems here. (1). The volume control on your monitor is turned down. With the button on the front of your monitor, find the menu/option button, and look for volume control (2) The volume coming out of your computer is low. Double click on the speaker at the bottom right of your screen, located on the start bar. Use the sliders to change the volume. This should fixya up.
This is a piece of **** unit. Mine only works on the left side, sometimes. When those times are I have NO idea. It doesn't seem to play 5.1 correctly and it goes into speaker protect mode for NO reason. It is TRUE lemon !!! ..let me know if you have any other problems with this JUNK [email protected]
the DVDS151 has its own built in volume control that is easy to hit the buttons near the bottom of the remote and accidently turn the volume down. even tho your tv volume is set high it won't pass the sound to the tv if it is on mute or turned down.
If the problem happens when you use your remote, you have some bad buttons on it.
If you can't adjust the sound from the front control panel then you have a problem inside your tv. If this is so then you'd need to have it checked out by a technician.
Stargazer
