"I have an Electrolux EOEE63AS oven (Australia). The temp is off by 20-30 degree's either way. I have messured the room temp resistance on the Temp sensor (550 ohms). I have seen some information showing this is fine and some stating 1000 - 1100 ohms.
The Electrolux ovens usually used PTC thermistor PT500.
Resistance of PTC sensor depending on ambient temperature and should be around 550 ohms on ambient temperatures between 20-30 Celsius. I would like to check insulation rasistance between metalic housing and each connection terminal. The rasistance should be higher than 2 MOhms.
Dado
SOURCE: GE JTP56 Double Oven
Hello there, This may be related to the F7 problem even if you are not getting an error message. Go to my web site at the following link: http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf Please let me know if this works for you. I have sent my fix to over 1300 folks. Good Luck, Powerman
SOURCE: GE Oven JKP26GP2 getting F2 error, even when not
F2 usually means the temp sensor is not working. here is a link to "F" codes.
http://www.repairclinic.com/0078.asp#JennAir
It has many manufacturers listed,so scroll to the GE ones.
The reason it beeps when not in use is b/c the EOC is reading the error in the part.
Good Luck!
SOURCE: My friend has a GE
Thank you for contacting Fixya.com. In electronic ovens the digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. Also you can calibrate the temperature using the key pad. Check the owner's manual regarding this. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. When you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat. Please get back to us if you have any further query.
SOURCE: What should an oven temp sensor's ohm reading
The oven sensor should be between 1000-1200 ohm's at room temperature or roughly 1080 ohm's. I would place the Tech Sheet here but Whirlpool will not allow me to post their manuals or Tech Sheets. You are welcome to the Tech Sheet HERE I hope this helps Thanks, Sea Breeze
