What fuse to use in 50 watt gorilla guitar amp?
Gil Shultz
  • Audio Player... Master
  • 3,464 Answers
The correct one of course. Anonymous!!!!!!!!!
Posted on Nov 04, 2014
I have a Peavey Bandit 50 watt guitar amplifier that has no output with the exception of what seems to be a 60 cycle hum.
The schematic I grabbed from blueguitar.org shows several fuses in the power supplies. Did you check those, especially the one for the high voltage supply for the output tubes - fuse F1 on 'main board' ?
Can these amps be BOOSTED to 50 watts rms?
No. The power supply is not high enough voltage to get that power and the speaker would not take that much RMS.
Buy a suitable sized amp.
1helpful
3answers
My line 6 spider III 15 watt amp isnt working properly. i turn it on but i get this sound when its connected to the guitar. it sounds like when a guitar is not connected to a guitar and the guitar cable is...
While it could be true that you're having a problem with the guitar or cable as the previouse expert suggested, to say that it can't be anything else is false. It could be a jack problem...it would only be apparant when the jack is making contact with a cable. I do think you should test it with another guitar and another cable but if that is not solving the problem then I bet it's a problem with the input jack of the amo itself or even one of the ionternal components (this is a digital amp and there are MANY components and settings that can trigger a problem like this) If the problem is not solved with a new cable/guitar configuration then it's time to take it to the shop.
1helpful
My marshall mg50 dfx keeps cutting out and stuttering, any idea what the problem is? It sort of cackles as well when the volumes increased giving me different variations in sound.
As a guitar player myself learn that not all speaker from some amps hold the ouput wattage. The fuse could ba a problem or the speaker is giving out.
1helpful
Fuse - 2amp for a Silvertone 1472 Amplifier
Hello endaya try www.digikey.com if you are using a 2amp buss fuse, its available, 117V is applicable to 220V, just follow the amp rating.
Marshall JCM 2000 dual super lead 50 watt going out on me
Very nice amp!
First off, is the amp getting sufficient power? An unreliable AC current from your wall can affect the performance.
Have you tried the amp with a different speaker? Checked for a loose connection from the amp to the speaker? Is it the correct ohms rating?
Second, are you experienced in electronics? The problem could lie in a faulty solder connection, a bad component, etc.
If you are not confident in opening the amp and troubleshooting it yourself, take it to a audio repairman. Marshall's are some of the easier ones to fix.....
Guitar amp shows power but has no sound, could it be a blown fuse
Nine times out of ten, any problem with an amp having no sound coming out, it's a wiring issue. Make sure all of the wires internal to the amp are propely hooked up. Also, try switching out the quarter inch cord you are using from your guitar to your amp. Could be a bad cable. Unless you have blown the speaker completely, something is loose or not hooked up properly.
2answers
Inverter problem
If you got the store bought APC 350 UPS, you most likely overloaded them, and killed them beyound repair.
People should never buy a 350VA. They are way to small for power supplies most of us now have. you need to start out to 1000VA plus you need to do the math to figure out how big of a UPS you actually need in the show room.
What am I talking about? What is the significant, or the math of what I am saying here. 115V x 1 amps = 115VA x .778 power factor = 89.47 watts Start up 50 watts = 39.47 watts
115V x 2 amps = 230VA x .778 power factor = 178.94 watts Start up 50 watts = 128.94 watts
115V x 3 amps = 345VA x .778 power factor = 268.41 watts Start up 50 watts = 218.41 watts
115V x 4 amps = 460VA x .778 power factor = 357.88 watts Start up 50 watts = 307.88 watts
115V x 5 amps = 575VA x .778 power factor = 447.35 watts Start up 50 watts = 397.35 watts
115V x 6 amps = 690VA x .778 power factor = 536.82 watts Start up 50 watts = 486.82 watts
115V x 7 amps = 805VA x .778 power factor = 626.29 watts Start up 50 watts = 576.29 watts
115V x 8 amps = 920VA x .778 power factor = 717.76 watts Start up 50 watts = 667.76 watts
115V x 9 amps = 1035VA x .778 power factor = 805.23 watts Start up 50 watts = 755.23 watts
115V x 10 amps = 1150VA x .778 power factor = 894.70 watts Start up 50 watts = 844.70 watts
115V x 11 amps = 1265VA x .778 power factor = 984.17 watts Start up 50 watts = 934.17 watts
115V x 12 amps = 1380VA x .778 power factor = 1073.63 watts Start up 50 watts = 1023.63 watts
115V x 13 amps = 1495VA x .778 power factor = 1163.11 watts Start up 50 watts = 1113.11 watts
115V x 14 amps = 1610VA x .778 power factor = 1252.58 watts Start up 50 watts = 1202.58 watts
115V x 15 amps = 1725VA x .778 power factor = 1342.05 watts Start up 50 watts = 1292.05 watts
115V x 16 amps = 1840VA x .778 power factor = 1431.52 watts Start up 50 watts = 1387.52 watts
115V x 17 amps = 1955VA x .778 power factor = 1520.99 watts Start up 50 watts = 1470.99 watts
115V x 18 amps = 2070VA x .778 power factor = 1610.46 watts Start up 50 watts = 1560.46 watts
115V x 19 amps = 2185VA x .778 power factor = 1699.93 watts Start up 50 watts = 1649.93 watts
115V x 20 amps = 2300VA x .778 power factor = 1789.40 watts Start up 50 watts = 1739.40 watts
1helpful
What size fuse do i need for amp
start with a 50, may need to increase it if you are not using a large capacitor.
600 watts = 12x
x= 600 watts / 12 volts
x = 50 amps
 Grubhead
Grubhead
Marvin
Marvin
