Burners work fine, no power to oven. Control panel is blank and door locked shut.
SOURCE: kitchen aid model# kgri801pbs
On most models, the door stays locked during a self clean, until the temperature returns to normal for safety reasons.
It sounds like your unit may have tripped a breaker during this self clean event. Check your panel for a tripped breaker. If the oven has cooled down, and the lock is still engaged, then we may have a different problem.
Let me know what you find out!
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
SOURCE: Self cleaning attempt has shut down the control panel.
You need an air flow kit, part 81911788 and a professional to install it.
SOURCE: Kitchen Aid Gas Range Architect Series II-self
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
