Question about Electronics - Others
I'm trying to run a 750 watt whirlpool compact microwave with a 2500 watt Cobra inverter. The microwave runs normally, but it won't heat. If I plug it in at my house it heats fine. I'm stumped. I load tested the inverter with two hair dryers and the microwave and it seems to have good output.
Larry
  • 2,812 Answers
I assume your not using a pure sine wave inverter. A lot of electronic devices won't work on a lower cost inverter (modified sine wave) that has a square sine wave, either invest in a true sine wave inverter or don't run sensitive electronic equipment, I'm somewhat surprised you didn't damage the circuit board in the microwave...Below is a link of a inverter that would work if you want to spend the money for one.
2500W 5000 Watt Power Inverter Pure Sine Wave 12V dc 110V 120V ac LCD...
Posted on Feb 05, 2018
3 Related Answers
Anonymous
  • 4 Answers
SOURCE: Low voltage output from inverter
I am thinking this a high impediance device problem and this is normal operation - the user manual of my inverter warns about use with high impediance devices - if not I am interested also...
Posted on Mar 03, 2009
Anonymous
  • 46 Answers
SOURCE: Inverter not working
unless you are into electronics it is cheaper to replace it! take it to a repair shop for an estimate
Posted on May 28, 2009
Anonymous
  • 4 Answers
SOURCE: power inverter
There are 8 40A fuses inside this unit. In the following pics you will see a bank of 4 and another bank with 3 of the 4 removed. I'm currently working on mine as it will cost me more to ship and have Cobra repair than I paid for the unit ($133 to repair). Good luck with your problem
Posted on Aug 24, 2010
I have a 2500 watt cobra inverter and I'm trying to get my 700 watt microwave to work but it keeps poping the breaker and shutting off Not sure why
Instantaneous surge current can trip the breaker. You need to look at the data plate on the oven to see what the actual draw off the mains is. 700 watts of microwave power is NOT the amount of power drawn when it starts. You have the fan motor and the tray rotator motor to deal with when calculating the correct size of inverter to use with it.
Sep 21, 2016 | Microwave Ovens
My morphy richards p80d20p-yu microwave runs normal but won't heat food
The problem is caused by a bad magnetron, inverter board, "7 years old or less" and possibily the keypad control board.
May 02, 2012 | Microwave Ovens
The output(w) is indicating o.oo and it's indicator light is red .I only have a couple of floor model fans plugged. Should it be showing something and should the light be green?
inverters run on a square voltage unlike normal 110 runs on a round voltage, the only 2 things that won't run on the inverter is fans and electric blankets
Jul 22, 2011 | Cobra 2500w Power Inverter
I have a 900 watt microwave when i turn my microwave on it blows the fuses in my cable what size fuse do i need
hi there, if you're using your power inverter to run your microwave oven isn't it? surely it is not advisable to plug this appliances for this really consume a lot of power...and eventually overload your PWR Invrter..if you use you power inverter in diff. load like lightings or a small dvd plyer and runs smoothly...is your microwave has no deffect if plug in wall socket and still blown the fuse...you have a deffective microwave oven..every time you replace the fuse w/ same type or ampereage and still blown you have a shorted power supply...try to bring your microwave oven in service center...nice day..
Feb 12, 2011 | Cobra 2500w Power Inverter
Can a 2500 watt inverter run a 5000 btu air condition?
5000 btu consumes about 500 - 700 W in cooling and obviously it should be running from 2500 W inverter.
It is obviously, but the conditioner has a compressor which needs some more (about 2, 3 times the rated) starting power, which is in it's bigger part reactive power which is not produced by the inverter and depends on the output condensers of the inverter.
It should be tested, and if the start is difficult some more condensers may be added.
Jul 17, 2010 | Cobra 2500w Power Inverter
2500 watt inverter 6 months old is starting to
It sounds like the fan is failing.
Good Luck,
Gilshultz
Dec 03, 2009 | Cobra Electronics - Others
Power inverter
Jun 18, 2009 | Cobra 2500w Power Inverter
Generator fails to start microwave
I had to buy a 2000 watt inverter type to run mine
Apr 06, 2009 | Whirlpool GH7145XF Microwave Oven
Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
Feb 26, 2009 | Vector VEC056 MAXX Power Inverter
Electronics - Others Logo
249 people viewed this question
Top Electronics - Others Experts
Tom Chichester
ray gallant
Are you an Electronics - Other Expert? Answer questions, earn points and help others
