Most likely because the newest maps are too large to fit on your device now. If you go to settings maps then my maps it will probably say lower 49 NW (north west) or NE (North East). Just buy a 4 or 8gb micro SD Memory card, stick it in the unit and run the update again but tell the program to change the coverage.
SOURCE: traveling out of home state and cant program address
Hmmm, do you have all states (full coverage), if not you need an upgrade to unlock full us coverage, if yes, select navigate to / state / city / street / number. Can't be that difficult can it?
SOURCE: MY GARMIN NUVI 760 says north on a road when it should show south
Sounds like the map needs an update if it doesn't show roads that actually exist.
Peter
SOURCE: Just got a Nuvi 1300T. Am driving from Michigan
TRY A SOFTWARE DOWN LOAD FROM WWW,GARMIN.COM
AND CHECK THAT THE FUSE IS OK IN THE CHARGER lIGHT WILL APPEAR ON THE PLUG, AND WHEN SWITCHED OFF A "CHARGING " MESAGE WILL APPEAR IN THE SCREEN
SOURCE: giving bad directions nuvi 780
Check your settings. The unit allows you to set it for Fastest Time or Shortest Distance. You should also make sure that it is not set to avoid major highways, as can also be done.
SOURCE: how do the updates work
Details on how to update your garmin satnav are at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
