I've had it for about 10 years and it's always worked fine. All of a sudden, it won't stay turned on, unless I hold the button down with one finger or thumb. How do I fix this?
DysonFan had it right. I read this article and fixed it successfully:
http://www.fixya.com/support/t890676-dyson_animal_hold_switch_work
SOURCE: power won't stay on unless you hold the button
You can't fix this problem yourself - a repair dealer needs to open up the button and inspect the power switch - call the Dyson helpline, they will find the closest authorized dealer in your area and if your machine is still under warranty it'll probably fixed under warranty for you.
SOURCE: Dyson dc14 power button
I just had this same problem tonight. As I was looking on this sight to find a solution, my husband fixed it. First he removed the extended handle part, then he took the 2 screws out behind the power switch and removed the front cover (directly underneath the power button). He then removed the plastic power switch cover and took the power leads off the switch and removed the switch and tapped on it, then the little button stuck in place:) Sounds silly but it worked! Good luck!
SOURCE: dyson dc14- power switch wont
Three options here,one,take it to a shop and have the switch replaced,two,tape it in the on position,or take the switch out and bring it to Radio Shack,they will have a switch that can be used as a replacement.
SOURCE: My dyson power button won't stay on unless you
Sorry to hear you're having difficulties with your DC24. If the on/off switch won't stay down, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
SOURCE: The power button on my Dyson DC19T2 won't stay on
The switch is broken. If you are handy, remove the old switch and match it up at a hardware store or a Vacuum repair shop. It shouldn't cost much to have it replaced by a proffessional either.
