Canon PIXMA  MP530 All-In-One InkJet Printer Logo
A
Anonymous Posted on Jun 29, 2014
Mp5320 error code u052 - Canon PIXMA MP530 All-In-One InkJet Printer
jmhh
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jul 29, 2014
jmhh
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
43593
Points
Http://www.fixya.com/support/t383287-canon_mp530_u052_error
be sure to purchase the correct replacement part
Code U051, change the cartridge color and it is the same.
The error U051 / U052 indicates that a communication issue with the print head. This can be caused either by the print head not being installed or print head not working properly. The issue U051/U052 canon printer can be fixed easily.
·Reset the print head
·Restart the printer
·Check ink cartridge
Read continue the steps to fix the U051/U052 error code in canon printer.
Why my printer mp610 shows code U052, what does it mean?
The U052 printer Error occurs in two different scenarios. The First one is when the print head is not installed properly on the canon printer. And the second Scenario is When the print head is installed well but is not working properly.
Follow the steps to fix the U052 printer error code. Need any type of help contact printer experts through Free Live chat.
5answers
Errr u052 cannot print .
A lot of Canon printer's users come across with the error message, "U052 This type of print head is incorrect." It is a very common error on Canon printers and is fairly easy to troubleshoot.
There are two different scenarios related to U052 kind of error message.One is where the print head is not installed at all and then it is giving the 'U052 This type of print head is incorrect' error message.
And, the second scenario is where the print head is installed nut it is not functioning properly or probably not working at all. The below section will show step by step troubleshooting of both the scenarios.
Error message U052
U051 indicates an ink cartridge that cannot be recognised by the printer. Sadly you cannot use your printer while this error remains.
I would advise the following:
-Remove the problem cartridge from the printer
-Wipe the gold contacts on the front of the cartridge with a piece of non fibrous tissue (like kitchen tissue).
-Re-install the cartridge.
If the error remains it is likely that there is a genuine problem with the cartridge. So I would advise getting in touch with whoever you purchased the cartridge from to arrange a replacement.
2answers
Canon MP660 U052 Error
Remove and reinstall your Printer Cartridges. Else, you will need to take your printer to a Canon Service Center to have them replace your faulty Print Head / Temperature Sensor that is causing the U052 Error.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
4answers
How do I deal with the Check Cartridge U052 message
Solution 1:
  • Remove and replace the cartridges.
Solution 2:
  • Insert new cartridges
Solution 3:
  • Reseat the print head to correct print issues or clear an error.
Solution 4:
  • The print head is broken and it must be changed by a new one.
Source:
http://fix-your-printer.blogspot.com/2010/11/error-u052-on-canon-printers.html
1helpful
2answers
Error code U052 how do I get rid of it for good?
U052 is a temperature sensor in the works below the cartridges. Canon can ship you the part; it's not the inks cart, but then it's not for me to say 5 minutes with the power off or 20 with either a solvent cartridge (especially on any colors with stripe dropouts) or cleaning the works and reseating flex cables won't fix it. (Take it to a Canon shop per any surviving repair warrants; it's serious enough.)
2helpful
Printing Error...
Hi!
The U052 error means that the 'chip' fitted to the Cartridge is not responding . They fit these chips to try to prevent refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and the chips are particularly sensitive to static / damage. Many people end up blowing the chips during the swap over
Please rate this solution.
Thanks
Rylee
22helpful
2answers
Pixma mp600 error code u052 ,type of printer head is incorrect. Need to know how to remove & reinstall as pre instructions on page 69 of manual
Got the error U052.....with incorrect print head. Has been printing just before. How do I remove the printhead and place it back in. My printer is Canon MP610
old marine
old marine
ZJ Limited
ZJ Limited
