I have a brand new Bosch Axxis washer. On the very first day that i used the machine, it started to work normally and I washed 2 rounds of clothes. however, during the third round, something went wrong and now 3 signals on the control panel (spin, regular spin and end) are blinking together. what should I do now?
SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
SOURCE: Bosch washing machine leaks at right bottom
The part that you removed, was the pump filter, the pump is located behind the filter, possibly, the pump itself is leaking, or the filter cover is not fastened in tight enough, pr the filter seal is defective, if after tightening, it still leaks, suggest you replace the pump.
Please rate my solution.
Thanks.
SOURCE: I have a Bosch washer, model number WFK 2401 that
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
SOURCE: Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
