Thin black lines running up and down all over the screen. What is wrong?
SOURCE: Horizontal green line appears on screen
my maxent plasma tv has the same problem but it has green and red lines. I found out that hitting the tv from the back works. It used to last a long time but now i have to get up now and then to slap the tv on back with my hands! anyone with a long term solution?
SOURCE: green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
if someone found a solution for the verical line please post it. the laptop has never been hit and the vertical line just showed up there...
SOURCE: Horizontal and vertical lines on the screen
i do no know take it back to the shop you got it from
SOURCE: line accross top of the screen with flashing black and white boxes
Go to menu and settings and look for OVERSCAN and set this to on and hey presto no more white lines no matter what ratio your in.
