I want to transfer my text messages to my computer and have tried everything I could think of. I called LG tech (supposibly)and he couldn't find anything either. Said there is actually no way to do it. I do have a SD card but I can't get the messages to move there either. The phone was set to save to phone I just changed that to save to memory card. Any help would be appreciated. Thanks This is making me crazy.
SOURCE: Text messaging/Memory Card
okay, I will try to help you. On your telephones main screen, where there are all of the icons, tap the first icon, the one with 4 dots, then, on the next screen, tap the 3rd icon, and you should see two files, one says OTHER FILES and the other file is MEMORY CARD. If you see this, then we know your phone is recognizing the memory card. Yes, then proceed. If not, then it could be your memory card is defective, not configured properly or any myriad of other problems I have no clue how to fix....
Let us proceed....
back out all the way to the main screen we started from. lets try to copy and paste. Tap the 4-dots icon again, and then tap the third icon on the next menu. Then, tap the audio and ringtones icon. Try to select one of the ringtones and then, tap options. You should see copy, tap that choice, and a screen should pop up asking you handset memory or memory card. Here is where you choose to save it to the memory card, then, highlight that choice and then hit okay. It will take you to memory card folders, tap wichever folder you like and then, at the right hand bottom you will see paste. tap that, and it will paste it to the folder you chose. This is how you can also save texts I guess, as I never used that feature, and I would think that on your memory card you only need to make a folder named texts and then copy and paste them to this folder. Try it and let me know if it works for you, if not I will try to help again. Hope this helps!
Aisha
SOURCE: lg kf600 sd card
I don't think this is possible with object push. (I think you want to transfer files from your PC?). You can however explore your PC from your phone, select the file and transfer it to your phone. If the sdCard is in your phone you will be asked where to save the file (on the phone or on the external memory).
Hope this helped
bye
SOURCE: How can I save text messages on my LG CU720 shine
you really cant persay. believe me i've tried. the only thing to do is click on forward message and type in email address and it will send to your email.
