Question about Hotpoint NVL333GY Gas Dryer
Gas dryer is not heating up
We have a Hotpoint gas dryer and it quit heating up. We replaced the igniter, note that there is a glow underneath the dryer, but the dryer still does not heat.
Posted by needhandyman on
  • 3 more comments
  • Anonymous Sep 27, 2008
    will not get hot at all made sure propane tank is full
    dial does not move when heat is not working
  • sasser2323 Oct 05, 2008
    dryers does not work on heat and need to find how to reset element
  • Anonymous Nov 13, 2008
    Hello, I am having the same problem as these people, my igniter heats
    up and ignites the gas, then it goes out and does it again. I replaced
    the burner coils and still the same thing. Good igniter, and good
    burner colis, what do you think I should try next?
  • Anonymous Mar 15, 2014
    Dryer quit getting hot
  • Anonymous Mar 28, 2014
    not heating
Anonymous
Hello, I am having the same problem as these people, my igniter heats up and ignites the gas, then it goes out and does it again. I replaced the burner coils and still the same thing. Good igniter, and good burner colis, what do you think I should try next?
Posted on Nov 13, 2008
Gerald Griffin
  • 248 Answers
Could be a bad set of burner coils. Does the glow come on for a bit then goes out. And after a bit does same?
Probably bad coils. If you were able to change ignitor, you can do the coils. Unplug first! The coils are the 2 black cylinder shaped devices on burner. They are held on with a bracket that has 2 phillips screws. You can probably take them to your parts house and they can ohm them out for you. Make sure to write down their position before removing them.
Posted on Nov 07, 2007
What to do when dryer runs but does not heat up
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse , coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Problem -
Gas flame comes on first few times then quits and igniter keeps cycling on and off but never lets the gas go.
Answer ( most common ) -
Replace the coils on the Gas Valve.
Problem -
No flame, no igniter glowing at all,
Inspect igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter when dryer should be calling for heat.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Whirlpool LGR5636L Gas Dryer
HOW CAN A DRYER IGNITE A FLAME AT FIRST FOR TEN MINS THEN WHEN THE DRYER WANTS TO HEAT UP AGAIN I SEE A GLOW BUT NO FLAME COMES THE SECOND TIME SHOULD I REPLACE THE THERMAL FUSE
No you should replace the coils. 3a3915a.jpgWhy? You know you are getting power to the gas assembly so that means the fuse and control are functioning. The igniter glows so that is good. The Flame detect is fine because it shuts down the glowbar when it heats up. So those pesky coils get hot and quit. They eventually cool back down and work a little more, very aggervating to diagnose but easy to fix.2b3709e.jpgNote you do not have to remove the gas assembly to replace these coils.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 23, 2010 | Whirlpool Dryers
Gas dryer works, but does not heat
Hello there:
here is a discriptive way of trouble shooting the dryer and it lists the common components that will normally fail if the element has not failed first
Gas Dryer Diagnosticsgasdryerguts.gifThis picture shows the main parts of a gas dryer's burner systemthat can fail. Understanding each component and it's failure mode canreally help diagnose a problem with a gas dryer.
Ignitor failure: The drum turns but the igniter doesn't glow, thereis no clacking sound as the gas valves open and there is no flameignition sound.
Radiant Sensor failure: The drum turns but the igniter doesn't glow,there is no clacking sound as the gas valves open and there is no flameignition sound.
Gas Valve Solenoid failure: The drum turns and the igniter glows andgets turned off but there is no clacking sound as the gas valves openand there is no flame ignition sound.
And another component failure to be aware of, but that's not shown here, is the operating thermostat:
Operating Thermostat failure: The drum turns but the igniter doesn'tglow, the gas valves don't open (there is no clacking sound) and thereis no flame ignition sound.
And here's a picture of other components to ohm out if you're getting no heating at all:
Nov 21, 2009 | Hotpoint Dryers
Hotpoint aquarius ctd00 does not blow hot air
If gas, check the following.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
If electric, check the following.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Jul 09, 2009 | Hotpoint Dryers
Dryer not heating
1. Gas valve coils
2. Thermal fuse
3. Igniter
2. Heating element
3. Thermal fuse
Jun 25, 2009 | Hotpoint Dryers
Kenmore Elite HE3 Gas Dryer - Heat flame will not ignite
The Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Jun 20, 2009 | Hotpoint NVL333EY Electric Dryer
Alg331raw gas dryer. Runs but no heat. Worked
Check the following to address this issue
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 04, 2009 | Amana ALG331RAW Gas Dryer
No heat it starts but the igniter doesnt light the gas
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor does not glow then the thermostat is bad.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.   If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Jun 02, 2009 | Dryers
Heat not consistent
The air holes in the back of the tub are they clear and unobstructed?
Jul 25, 2008 | Hotpoint NBXR463GBWW Gas Dryer
My gas dryer only heats up the first time...
replace both coils on the gas burner (the round black dohickeys)after first ignition they tend not to pull valve open next time heat is called for
Jun 06, 2008 | Hotpoint NBXR463GBWW Gas Dryer
Hotpoint NVL333GY Gas Dryer Logo
326 people viewed this question
Top Hotpoint Dryers Experts
peter gittos
peter gittos
Marvin
Marvin
sharky69x
Level 1 Expert
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
