I personally wouldn't replace a safety device (placed there by lawyers, lawsuits and the all knowing government) with anything other than OEM. While it's very likely that one manufacturers flammable vapor sensor may interchange on another brand of tank, I think it's highly unlikely that EVERY manufacturers sensor will work on every other brand of tank
I answer questions for free. My job is to provide resources that help you for free.
1) That being said, my research into FVIRs says you need a plumber when the FVIR trips. 2) The use-and-care manual for your model also says call a technician. 3) Buying replacement parts through a plumber is true for all water heaters except the Bradford White which has a resettable FVIR. BW is the only company with a re-settable FVIR, however the water heater market changes daily.
4) If the FVIR shorted and shut down the water heater, it probably saved a fire and maybe saved a life.
Certain Rheem water gas water heater models feature electronic controls with a flammable vapor sensor installed on the bottom portion of the water heater unit. This sensor is designed to shut off your water heater system to prevent fires in case flammable vapors are present within the area. If your flammable vapor sensor caused your water heater to shut down, check the area immediately for leaking gas or other flammable products. Common household chemicals such as bleach can also trip the safety system as well as unsuccessful burner ignition attempts.
White Rodgers Intelli-Vent PowerVent Control Equipped Models
Step 1
Turn the water heater's blower switch off and disconnect the power cord for the water heater (refer to your particular model's operation guide for the exact location of the blower switch). Disconnect the Molex connector attached to the bottom of the control pad (the left most connector with five pins).
Step 2
Turn on your multi-meter and set it to read resistance or "ohms". Connect one of the multi-meter's probes to the number two pin and the other probe to the number three pin of the Molex connector (middle black wires). If the reading on your multi-meter reads below 9k or above 45k ohms, the flammable vapor sensor is faulty and in need of replacement; you cannot reset the system until this issue is resolved.
Step 3
Reconnect the Molex connector to the bottom of the control pad, reconnect the water heater's power if and turn the blower switch to the "ON" position. Press both the left and right buttons on the control pad at the same time. Wait for the green light on the control pad to blink and press the following buttons in sequence: Left, Right, Left, Left, Right, Left, Right, Right (you will need to perform these actions within 30 seconds of reconnecting the power cord to the water heater in order to be successful).
The part you need is actually the following as it was made for Whirlpool by AMERICAN WATERHEATERS:
Part for AMERICAN WATERHEATERS, Model # E2F80HD045V
Number:
4710185
Category:
Plumbing and Heating
Length:
53.90
Width:
1.10
Height:
1.00
It is sold by Sears and is available for $17.99.
Good luck with your repair!
Clear the area around the bottom of waterheater so as to allow air flow around mesh area built into base of water heater and or open unvented door passages involving waterheater. This mostly a safty issue which seldom occurs if not remedy quickly.
