Olympus FE-210 Digital Camera Logo
Question about Olympus FE-210 Digital Camera
Why does my sz 30mr olympus camera always says battery empty! Help
5 Related Answers
Anonymous
  • 154 Answers
SOURCE: Olympus Stylus 1000-- The camera is not reading
Your camera may be ok. Every and each camera has different reactions to a battery condition depending on the design of the circuit. Your battery may work ok on the other camera but this camera needs more juice (assuming the camera is working ok). If the camera demanding more power from the battery, try the rechargable batteries. Hope this helps. -James
Posted on Mar 28, 2009
Anonymous
SOURCE: after charging the battery i put it in my camersa and it reading batttery empty
This happened to me before and its because i put the battery in the charger the wrong way up. Make sure you put it in so that the side with OLYMPUS in it in big letters is facing up!
Posted on Apr 25, 2009
Anonymous
  • 240 Answers
SOURCE: "Battery Empty" Message
olympusamerica.com/files/FE-360_X-875_C-570_FE-20_X-15_C-25_Instruction_Manual_EN.pdf
this might be useful for u
Posted on Jun 18, 2009
Anonymous
SOURCE: "battery empty" on screen after I disconnected camera from compu
Hi, have olympus fe-280 camera. Battery on screen shows full but shows empty (an inch strip) in middle. I have charged it. Even bought a new battery. Can anyone help. Thank you. ...... I want thinking I may have two faulty batteries and just need to buy another one?!
Posted on Sep 06, 2009
Anonymous
SOURCE: The battery died in my Olympus 850SW camera, I
the battery is probably too old
Posted on Oct 15, 2009
Need a manual for Olympus SZ 45 stereo microscope # 345483
I have searched but have not found a manual for an Olympus SZ-45 camera.
If you have any other information to provide, use the Comment menu to add it to your question.
My olympus sz 14 camera shows Zoom error on the screen when I turn it on and then turns off immediately. I bought a new battery a d charged the camera but it continues to shut off.
The "Zoom Error" message that appears on your Olympus SZ-14 camera's screen when you turn it on, followed by the camera turning off immediately, could be caused by a problem with the camera's lens.
Here are a few things you can try to troubleshoot the problem:
  1. Turn off the camera and remove the battery and memory card. Then, wait for a few minutes before re-inserting them and turning the camera back on.
  2. Try gently tapping the camera on a flat surface to try and realign the lens.
  3. Check the lens for any dirt or debris that may be blocking the movement of the lens. Clean the lens with a soft, dry cloth.
  4. Check the lens for any physical damage like dents or cracks.
  5. Try using the camera without the zoom function to see if it still turns off.
  6. Contact Olympus customer support: If you have tried all the above steps and the camera is still not working, it may be best to contact Olympus customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
It's important to keep in mind that the Olympus SZ-14 is an older model camera, which makes it harder to find replacement parts and professional repair services. If the camera is still under warranty, you may be able to get it repaired or replaced by the manufacturer.
Where can I find an instruction manual for Olympus SZ model SZ-12 digital camera?
All user (instruction) manuals from Olympus can be found on the Olympus website. I most of the time go to the USA site, because they are more generous in providing support.
Sep 05, 2014 • Cameras
How to reset sz-15?
With digital cameras there are no things like reset buttons or procedures. Just switching off and on, or removing the battery and reinserting it, will restart the camera like a cold boot from a computer.
When you touched the lens barrel, while it was moving, and the camera acts strange. Switch it of, remove the battery and the memory card. then reinsert them and switch on.
Lost the CD-Rom for my Olympus SZ-12
You don't need the Olympus software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
I have an Olympus sz-12 that won't turn on even after continuous charging
im having the same thing. my sz-12 24x wont turn on and the battery is fully charged someone plz hlep
2answers
extra dose 12V power pinch for 3 sec
2helpful
2answers
Top Olympus Cameras Experts
Steven Wander
Steven Wander
David Shaub
Steve
Are you an Olympus Camera Expert? Answer questions, earn points and help others
