Question about Sub-Zero 690 Side by Side Refrigerator
Subzero freezer works refrigerator lights off and not cooling
When we opened the door to the refrigerator it is now dark...no lights on and it does not seem to be cooling. Freezer is working.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
You probably have a bad light switch.it's the one on the left up top. If you look closely you can still read the temperature in the display to tell if it's cooling.
Posted on Jul 30, 2014
6ya staff
SOURCE:
Rotu
Douglas Henry
  • 175 Answers
SOURCE: Subzero door left open - now acting strange
You have probably already figured this out, but if the door is left open there is a sensor that will turn the lights off to keep the fridge from overheating. After you close the door and let it sit with the lights off for 15 minutes or so, the sensor will cool and allow the lights back on. If the temperature reading in the window is ok and does not say "service" or "vacuum condenser", then you should have no more trouble.
Posted on Jun 13, 2007
Anonymous
  • 67 Answers
SOURCE: SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Posted on Sep 24, 2007
Anonymous
  • 26 Answers
SOURCE: Subzero 611 Refrigerator not cooling, freezer fine
It sounds like a defective ref section evaporator. This is common, due to poor quality metal used in fabrication. If you call subzero, they will more than likely fix it as they are aware of this issue. It probably wont cost you anything if you get them involved.
Posted on Mar 31, 2008
Anonymous
  • 8 Answers
SOURCE: Hi...need help...subzero 550
Make sure the condensor is clean, blow some Air though the Condensor to make sure good Air flow towards Compressors. also, you might have a bad defrost timer or Freezer Control... worst case you might have a bad Compressor... hope I can help....
Posted on Apr 15, 2008
Joe McG
  • 56 Answers
SOURCE: SubZero 532 frig lights out
There are two door switches one for fan and the other for the lights. With the compressor running, there are two so yu need to make sure it is the refrigerator and not the freezer, open the door and press the right switch and listen for a fan. The left should be your light switch and the problem is generally in the switch, on rare occasions there is a failure of bi-metal safety switch part number 4200850. One very rare occasions you may have a wiring proble.If you go to www.subzero.com there is a showroom locator tab on the top right corner, click it and you will go to a locator page which will get you to your local parts didtributor.
Posted on Dec 03, 2008
Subzero 650 LCD dark. Lights in fridge out. Lights in Freezer on. Unit still working. Any thoughts?
Most likely door switch assuming of course the bulb has been replaced
Nov 13, 2017 | Refrigerators
Subzero 611s freezer door will not open
It sounds like something has fallen to cause or it is badly frozen inside
Aug 17, 2014 | APW Wyott SubZero Refrigerator Freezer...
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
LCD panel and lights not working
On your Sub-Zero 642 Your display will not work unless your refrigerator lights work.
1st. Make sure your light bulbs are good.
2nd. Check your refrigerator door light switch.
3rd. The subzero uses a thermal overload to kill your lights if the door is left open to long.
http://www.on-timeappliance.com/subzero.html
Mar 26, 2012 | Sub-Zero 642
Samsung refrigerator rs2630sh condenser fan is not working. My Fridge is not cooling from yesterday. Tried to open the back panel at cabinet section and figured out fan is not working. When tried to keep a...
Hello Gopi Krishna,
Rather than enumerate the MANY MANY possibilities...
as simple as an ice BLOCKAGE ... or a DOOR switch...
Better ideas are also available on the following
PARTS-HOUSE assistance page...
Just keep in mind they would love
to sell lots of parts...
My first suggestion... would be to check your door closures... make sure your switches light and dark as you open & close the door...
Look through your freezer vents for a SOLID frost = trouble.
(not necessarily a bad thing... Fix = easy...
OPEN doors... power off: 3 days)
((watch-out for defrost over-flow))
http://www.appliancepartspros.com/parts-for-samsung-rs2630sh-xaa-0000.html
Jan 12, 2018 | Samsung RS2630SH Side by Side Refrigerator
Hi There My Parents have a Fisher & Paykel (E331T) the Freezer is working fine, but the fridge where the dairy products sit don't seem to be freezing at all im not sure if there suppose to be a fan...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | Fisher and Paykel Active Smart® E522BR...
Model gss20iepcbb freezer side works fine ...fridge
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
Sub-Zero 690 Side by Side Refrigerator Logo
179 people viewed this question
Top Sub-Zero Refrigerators Experts
John Tripp
John Tripp
louis_benton
Level 1 Expert
DOUG DYKAAR
DOUG DYKAAR
Level 1 Expert
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
