Hook up for sub woofer
SOURCE: Hooking up a klh PSW8-100 sub wofer
Hey you might find a solution on this audio and wiring blog: www.audioholicblog.com -- it has a blog about wiring your home audio system and the cables that you will need.
Hopefully this helps! Good Luck!
Dannyboy!
SOURCE: need wiring assistance
Just need to register, login and you can download manual from here.
It will take only two minutes.
Hope this helps.
SOURCE: sub woofer produces a very loud low tone
I have the same problem. JavaMan is right. In one case someone even reported the bridge rectifier had failed. I have mine apart right now, trying to decide whether to attempt to fix it. The power board has been warped a little from the heat, and I can no longer read the color bands correctly on the power resistors to try to change them. Thanks for the schematics, JavaMan; unfortunately they don't match my boards, so I'm out of luck, and can't find anything else.
The components aren't expensive, so you might be able to take it someplace and have it repaired (or have a friend do it) fairly cheaply if the schematics here match your sub. I think I'm gonna chuck mine, which I hate to do since the speaker and cabinet are still good. I've just wasted too much time on it, and already have another in its place.
SOURCE: Just got two AR 312
do not use those speakers with that amp, those are 4 ohm speakers, which could damage your 8 ohm yamaha amp. you will have to get a 4 ohm capable amp to run the highs, and another 4 ohm amp to run the subs.
car amplifiers are currently 4 ohm, or even 2/1 ohm stable, but few, if any modern receivers can run at anything lower than 8 ohms without a danger of overheating. you may have to get a vintage amp(s), like a 1970's marantz receiver, or a 1980's to early 1990's kenwood power amp, because 4 ohm home amps are pretty scarce nowadays.
whatever amp(s)( you get, verify that they are DEFINITELY 4 ohm stable.
SOURCE: KLH ASW8-100b Sub woofer. I
Some specific model numbers might lead us to specific manuals and specific instructions. To find a manual, maybe run it by the manufacturer
Depends on your source and its amplifer complement. Some can drive a subwoofer directly while others just produce a Line Level subwoofer output for use by a separate amp feeding a subwoofer or self-amplified sub.
The set-up of the source to produce a subwoofer output is totally dependent on its design. Generally, you have to 1) tell it you have a sub, 2) define how bass will be routed or shared among your various speakers accordingto their bass-handling capacities, 3) using test tones, set the relative ludness and crossover settings so you have a uniform sound field.
