Question about Rowenta Vacuums
Why my Rowenta Infinium Delta Activ does not work (filter clean and motor working
Posted by marta espanet on
Hi , I am looking for a Vacuum bag and filter for my Rowenta Vacuum cleaner Model number:RO1767R1 Type: VC20PE3 Ref. number : RO1767R1/4QO-3312R.
Here's one source for the ZR0039 01 paper bag and microfilter for the RO1767R1 compact canister vacuum: https://www.alza.co.uk/rowenta-zr003901-d308208.htm?catid=18850976 . This is a 6 pack of the bags. This vendor also has the Wonder Bag for this model: https://www.alza.co.uk/rowenta-compact-wb305140-wonderbag-d308211.htm?catid=18850976 . I can't find a source for the HEPA filter version (ZR0041 01).
This store has other locations. You can also find the vacuum bags here: https://www.alzashop.com/rowenta-zr003901-d308208.htm?catid=18850976 .
I hope this helps.
Jun 03, 2016 | Rowenta Vacuums
Why is motor intermittent?
Claire, if filter is clean and problem persist, return for exchange.
Feb 19, 2016 | Filter Vacuums
Motor( entire casing) is extremely hot after only 5 minutes of use
Check and clean all the filters in the machine and the hose. There will be at least a pre motor filter and usually a filter after the motor, could be a foam type or inside the casing. If there is a restriction to the air flow the motor is working harder and the motor relies on a good air flow for cooling.
Mar 08, 2011 | Vacuums
How do i clean my rowenta steam iron
run some c.l.r clear through it
Sep 25, 2010 | Rowenta Vacuums
Vacuum losing power
Sound like you may have a faulty circut breaker or thermal overload in the vacuum motor itself. If you got this vacuum from a specialty vacuum store you may be best to take it in under warranty. If you bought it from Wal mart, they will tell you that you have to go through the manufacture of the machine to get warranty work done... You might be best to take it in and have it checked.
Jan 19, 2009 | Rowenta Vacuums
Bosch vacuum Motor turns off after a few minutes
It sounds like you have a motor protection fuse that resets after an overheat/cooling cycle.These work the same as a circuit breaker in your house with the difference being they can reset themselves.The Bosch will also shut down if there is insufficient airflow and I would check your filters first.1) Pull the filter and let the machine run.Do not pick up debris when you operate without a filter-it will be drawn straight into the motor.If it runs fine without shutting down, all you need to do is change your filter.If it shuts down again check the external hose for any blockages.Also check the throat from the powerhead for any blockages.If you continue to have the same problem then you will need to replace the fuse because at this point you have eliminated all the other likely problems.Good Luck-Scott
Oct 08, 2008 | Bosch BUC11700UC Cyclone Jet Bagless...
Does not pick up anything and makes weird noise
I had the same problem with very low suction and weird noises, the orange light kept coming on.
I always empty the cannister and clean out any hair from the roller. I would take the filter outside and clean it as good as possible. I don't know if I can post a picture on here or not, but I will try. It is unbelievable how much hair comes from long haired girls. Particulary my daughter. Back to the point...
I was cleaning out a drawer one day and came across an extra filter. I put the new filter on, and its like brand new again!
Man, did I feel like an idiot! Just needed a new filter.
Oct 13, 2007 | Eureka 431A Optima Bagless Upright Vacuum
Vacuums Logo
56 people viewed this question
Top Rowenta Vacuums Experts
Andrew Taylor
Andrew Taylor
Are you a Rowenta Vacuum Expert? Answer questions, earn points and help others
