Question about Timex Ironman 100 Lap Triathlon Speed/Distance - 5E701
How to set up time and date
How to setup time and date
Posted by Shabbir Variava on
treeeee
    Master:
  • 519 Answers
Michael Carroll
    Master:
  • 742 Answers
Read the manual
little wonder on the web called a search engine, I googled it and found this in under 10 seconds.
Timex Product Manuals Downloads
Posted on Jun 29, 2014
Ferrari World Time watch setting, manual is awful and useless
You have to hold down B to set up T1 which is the time the hands will display. Once you see the City and T1 show up on the digital display you can go through the various settings to set time/date etc. Use B to cycle through setup and A to make the necessary changes.
Pushing the crown allows you to set up T2 or the time displayed on the digital section. You set this by choosing the time zone.
Hope this helps
Jan 05, 2015 | Ferrari FE-05-IPB-FC World Time Mens...
I need help on how to set the time on my newlec nl2chdpt1.Does anyone have instructions?
hold down green set + blue select
that will get you into time / date setup
Aug 31, 2013 | Watches
Have a new ULTRonic Global clock. Came in a box, well packed but apparently no setup instructions. Have been able to set the clock after much guess work. Temperature, Humidity and trend seem to work....
This is for Ultronic LCD clock/weather gadget.
keywords (from display)
Ultronic forecast week day humidity temperature trend comfort level
- DOWN = toggles F/C temp
- UP = toggles alarm
- MODE = selects date/time display
- hold down MODE to enter "set" mode for data currently displayed
- use momentary MODE to choose target item
- use UP/DOWN to change item
Nov 01, 2011 | Watches
I cannot set the time on a wr165
here's a simple instructions of setting your watch
Watch setup instructions
for the Armitron Instalite All-Sport :
Mode B / \ C Date
Light A \ / D Alarm
_____________________________________
Set time time / date
Press and hold B (Mode) untill alarm hours flash
Press D (Alarm) to advance these
Press B (Mode) again, seconds will flash,
press D (Alarm) to advance these
Press C (Date), minutes flash, press D to advance these
Press C again, hours flash, press D to advance these
Press C again, month flashes, press D to advance these
Press C again, Date flashes, press D to advance these
Press C again, Date flashes, press D to advance...... [suggestion from Chikita]]
Activating/Deactivating Hourly Chime
1. From "Normal Time Mode", press and hold "D" (Alarm) and
at the same time press "C" (Date) once. Hourly chime symbol,
( a house shape) appears in "chime" windows to indicate
the hourly chime will beep every hour.
Activatin/Deactivating Alarm
2. With "D" (Alarm) still pressed, press "C" (Date) again. Alarm symbol
( a clock shape with waves above it) appears in the
upper right to indicate the 24 hour alarm is now activated.
[I assume this "toggles" between off and on states,
so performing it again should turn off the alarm]
i hope this will help you.
Jul 22, 2011 | Armitron All Sport Digital watch
SETTING DATE JUST ROLEX
After you unscrew the crown it is already in winding position. If you pull the crown, it will go to the date setting position. Further pull of crown will set it in time setting position. Try to pull the crown till you get it in correct date setting position and change the desired date. Do not use the date setting between 10pm - 2am, as this can damage date mechanism. The best way is to pull out crown to the time setting position and set the time to 6.30(anytime) and then push the crown in to date setting position and change the date to the previous day's date. Then again pull the crown out to the time setting position and advance hands forwards (clock wise) till hands pass 12.00 (midnight) and the date changes automatically to the desired one, then adjust the time, push the crown fully in and screw the crown on.
Jun 01, 2011 | Rolex Lady Datejust 179173SRJ Watch for...
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
I have a Kenko KK-613D LCD clock which came inside a bathroom cabinet, but no instructions, can you help please.
BP Digital Clock Instructions (translated from French)
Manual:
1. To set alarm in normal mode press M twice.
Press S and D to set then press M to exit.
2. ADJUSTING the Time and Date:
Press M three times to go to setup mode
Press S to go on setting the minutes and press D for adjustment
Press S again to adjust schedules and press D to set
Press S again to adjust the date and press D to set
Press S again to adjust the month and press D to set
Press S again to adjust the week and press D to set
Then press M to return to normal. The previous settings are automatically saved.
Press D to display the date.
Oct 29, 2010 | Watches
Sunrise/Sunset Time and Moon Phase wrong on watch!
Just in case you're still interested in a solution. Your watch uses a geographical location and the current date to estimate the sunrise and sunset times. While the date (and time) information is, most likely, set on your watch correctly, you, probably didn't specify the geographical location (latitude and longitude, as well as the GMT correction for your time zone). Having setup correctly these parameters you'll enjoy the precise sunrise and sunset time. Good luck!
May 29, 2009 | Casio Watches
How to adjust time and date
To set the Time:
1. PRESS the [Select] button and hold in for 2 seconds. Located in Field 3, the seconds will begin to flash
(Fig. 11).
2. PRESS the [+] button to scroll the seconds upward or
PRESS the [-] button to reset the seconds to zero.
3. At the seconds desired, PRESS the [Select] button to move to the next setting. Located on right of Field 2,
the minutes will begin to flash.
4. PRESS the [+] button to scroll the minutes upward or
PRESS the [-] button to scroll the minutes downward.
14
5. At the minutes desired, PRESS the [Select] button to move to the next setting. Located in the center of
Field 2, the hour will begin to flash.
6. PRESS the [+] button to scroll the hour upward or
PRESS the [-] button to scroll the hour downward.
7. At the hour desired, PRESS the [Select] button to move to the next setting. Located in Field 1, the 24 or 12
hour clock setting will begin to flash.
8. PRESS either the [+] or the [-] button to toggle between the 24hr and 12hr.
Note: If the 12 hour clock is chosen either AM/PM will appear below the hour in Field 2.
9. At the clock setting desired, PRESS the [Select] button to move to the next setting. Located in the center of
Field 2, the year will begin to flash (Fig. 12).
10. PRESS the [+] button to scroll the year upward or
PRESS the [-] button to scroll the year downward.
11. At the year desired, PRESS the [Select] button to move to the next setting. Located in the center of Field 3,
the month represented by a number will begin to flash.
12. PRESS the [+] button to scroll the month upward or
PRESS the [-] button to scroll the month downward.
13. At the month desired, PRESS the [Select] button to move to the next setting. Located to the right of Field 3,
the date will begin to flash.
14. PRESS the [+] button to scroll the date upward or
PRESS the [-] button to scroll the date downward.
Note: Once the user has determined the year, month and day, the Wristop Computer will supply the day of the
week in Field 1. The American month/day -view can not be changed to a day/month -view.
15. At the desired date, PRESS the [Mode] button to accept the changes and return to the main mode.
Note: If the user does not press any button for 1 minute in the setup mode, the display will automatically exit
setup.
Aug 22, 2008 | Suunto Vector Wristwatch
Armitron m516 no setup instruction
Armitron has a website with instructions for some watches.
Apr 05, 2008 | Watches
Timex Ironman 100 Lap Triathlon Speed/Distance - 5E701 Logo
192 people viewed this question
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
Steve
Are you a Timex Watch Expert? Answer questions, earn points and help others
