How are battery an connections ? Do the headlamps work when this happens ? How familiar are you with the electronic on your vehicle ?
The chart indicates the modes detected and transmitted by the BCM:
This could be an ignition switch problem , a BCM - body control module , The ignition switch is a Discrete Ignition Signal to the vehicle BCM body control module .
The Body Control Module (BCM) performs multiple body control functions. The BCM can control devices directly connected to its outputs based on input information. The BCM evaluates this information and controls certain body control systems by commanding outputs on or off. The BCM control inputs can be:
GM has had a problem with ignition switches , but the thing to do is hook up a scan tool an check for the correct power mode .
Serial Data Power Mode
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the Body Control Module (BCM). The BCM receives 2 signals/circuits from the ignition switch. These are the Ignition 1 and Ignition 3 signals/circuits.
To determine the correct power mode the BCM uses:
The state of these signals/circuits, either switch closed (B+ = 1) or switch open (open = 0)
The status of the engine run flag.
Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid BCM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, B+, the modules will fail-safe to the "RUN" power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to "OFF-AWAKE". In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
You may want to take this to the repair shop an that doesn't necessarily mean the dealer !
SOURCE: driver side power seat 2001 Chevy Tahoe
as long as nothing is stuck in track and you hear no noise when using switches, look for broken wire at connector or in harness. ck fuse first of course, if blown, something may be stuck in track causing it to stop and blowing fuse
SOURCE: 2001 Chevy Tahoe with ABS & Brake light on.
I hope you have the problem fixed by now, but, it is the ABS control under the truck. You need to go under the hood and open the fuse box and disconnect the 60 amp fuse for the ABS, this will turn it off before it burns up. This however will also cause the traction assist off light to stay lit all the time. To the fix the problem you can pay tons of money ($700 or so) to have the dealership install a ABS control and the problem will happen again over time. Or, remove it yourself, go on ebay and ship it off to a guy who repairs them for about $150 and you will never have the problem again. Also, if you wrap your cable ends with plastic and protect them good, you can still drive you truck while the part is being worked on. It takes about a week.
SOURCE: chevy tahoe won't turnover, power
have to make sure the starter is getting power. make sure the engine will turn over by putting a socket and ratchet on the crank bolt and turn it to the right. the two wires to the starter is battery the big one and the little one is for the ignition. ground test light check big wire, then have a friend key it up to check the little wire.
Next time it won't start turn headlights on and see if they dim when you turn key to start, if they dim its most likely starter, if they don't dim possible starter switch, Have you tried to start it in neutral position? Try that, if it starts in neutral than its park neutral switch, if not could be starter switch, Just make sure you chk. all fuses and any relays associated with ignition first.
SOURCE: Chevy tahoe shuts off when driving
i am on here because of an issue i am currently having with a 2004 tahoe, but after reading some the other problems people are having i will let you in on a previous experience i had with a 2002 chevy truck. my previous vehicle was a 02 chevy 2500hd with the 8.1 and the problem started on day when suddenly it shut off. it did restart with no problem. i never had that problem again until a month later and 1500 miles away when i went to texas to visit my sister. this time it took nearly 30 mins before it would restart. it would crank over fine but no fire. then suddenly out of no where it would fire up like nothing ever happened. so anyways to make a long story short i visited two different gm service centers, they did tune ups and diagnostics, and handed me the bills for over 500 dollars and told me that should do it. yea right the problem continued and then i searched online and one item that kept coming up was the crank position sensor. after reading what those people were dealing with i gave it a shot. went to the dealer bought a new sensor ($99) took an hour to install it and i never had the problem again. one last thing im gonna add. i had a friend that drove a late 90s or early 2000s grad prix, she was having the same problem and had her car in and out of the shop and never got it resolved, i told her to have them check the crank position sensor and bingo, she never had the problem again.
