The product is Technics Direct Drive Turntable SL-D202. I bought this from a local charity shop for around 20 and it was a good buy and it works brilliantly! Until, I started to realise that I could not cue the record and that I was just putting it on. I don't know much about how to fix things like this for the SL-D202 but if anyone had any idea how to help me as this is my first vinyl player and I really can not afford another. The stop button works and the arm goes back to normal off position but it is just the autocue that does not work. Please help.
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
SOURCE: Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
hello
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
SOURCE: Technics SL-Q200 Quartz Direct Drive
Your best bet is to get a good quality switch contact cleaner to clean all the contacts on the speed control switches.
I guess the contacts inside the switches will have corroded slightly with your turntable having been stored in the garage.
SOURCE: Technics SL-J1 turntable drive belt
Hello Cliff,
You will need 2 belts, if the turntable belt is gone the other is not far behind . One for the turntable size 23.6 inch by .188 and one for the tracking motor that is in the top cover part, is a 3.0 inch by .046 belt. best place to get them is at kenselectronics.com part numbers 1407-201 and AV-SBS3.0 if you have been checking around you will see other sizes, I have a SL-J1 and have used these and they work perfectly.
Tony
SOURCE: I HAVE A TECHNICS TURNTABLE SL-QD35 THAT IS DIRECT
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
