Question about Electrograph Systems DTS42W 42 in. HD-Ready Plasma Television
Why does my sony tv and a DVD connected to tv, when turned on, shuts off right away?
TV was moved from one house to another on a truck. When connected to cable, DVD player, we turned on the tv and there was a red light that flashed on and 4 times and tv turned off..no picture. On the tv screen there is DVD in upper left hand corner. When I turn on the DVD it does same thing, turns on and then shuts off right away.
Posted by Sue R on
Thomas Smithbrother
    Top Expert:
  • Electrograph... Master
  • 3,698 Answers
Esupport.sony.com
Posted on Jun 29, 2014
Sony DVD/VHS player to my TCL Roku TV
You can use the RCA style jacks, Yellow for video White for left and red for right audio OUT . Connect the TV end the same way. Note the source input number on the connectors of the TV. Turn both the TV and the Sony on. On the TV, select the input number the cables are connected to and you will see the Sony . If there are no unused places on the TV to connect to then take off the antenna/ cable wire off the TV and put it on the ANT IN connector of the Sony. Obtain a jumper cable wire long enough to reach the TV from the Sony and select either channel 3 or 4 whichever channel is not used in your area on the back of the Sony. Now turn both on and select TV as the source and put it on channel 3 or 4. Now turn off the Sony and change the channel on the TV to any other one in your area. If there is no picture, then the Sony will have to be on while watching TV.
Sep 15, 2016 | TCL 40FS4610R 40-Inch 1080p 120Hz Smart...
How do I re-connect a VCR/DVD player to a Bravia? I have (!) video output and (1) audio output wire from the VCR unit and have tried a number of combinations without success connecting to the back of the...
The DVD/VCR player should have video (Y) plus right (R) and left (?) outputs that connect to corresponding inputs on the rear of the Bravia TV. You should be able to press the TV/VCR button on the remote to select that device as the input source.
Mar 17, 2017 | Sony BRAVIA KDL-20S3000 20 in. LCD TV
My 27" Hitachi TV is about 14-15 yrs. Last night
could be alot of things but it comes on by hitting it makes me think either a bad relay or solder connection on the pcb board
Jan 29, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Looking for the meaning of error code on the CED DUI or DU1 for a DCH3416
DUI is actually trying to display DVI on the box (the LED won't display the V and makes it a U). You typically see this error when your connected to your TV through an HDMI cable and the handshake for HDPC is lost. The box thinks your TV doesn't support it and wants you to change your connection. The error should go away once it finds that handshake. If you were using a different input on your TV, maybe a composite or something for a DVD, and then switch back it can get lost. If it doesn't clear right away try shutting everything off and turning it back on by turning on the TV first and then the box.
Jun 09, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Power turns off right away
Its correct, Sony is no more selling plasma and I think many companies has already shut plasma production and CRT TV as well.
All TV manufacturers are busy in LCD TVs.
Jan 17, 2009 | Sony WEGA KE-50XS910 50 in. HDTV-Ready...
Sony KV40XBR800
YOU MAY HAVE A BAD IC 2504 OR M BOARD EST $250.00-450.00
Sep 05, 2008 | Sony FD Trinitron WEGA KV-27FV310 27" TV
HDMI hook-up
Try scrolling thru the TV's video inputs. When you get the right one, the circuit will automatically recognize it and play provided it's connected properly
Jul 27, 2008 | Sony DVP-NS575P DVD Player
1996 sony projection tv model kp46s17
does the tv realy shut off or does the pic go away sounds like bad tube
Nov 03, 2007 | Sony KP-61V75 61" Rear Projection...
Electrograph Systems DTS42W 42 in. HD-Ready Plasma Television Logo
Top Electrograph Systems Televison & Video Experts
Marvin
Marvin
Are you an Electrograph Systems Televison and Video Expert? Answer questions, earn points and help others
