? 6:48 https://www.youtube.com/watch?v=xz3EPWHjj0A
Aug 9, 2012 - Uploaded by eReplacementParts.com
Dammaged pivot springs can prevent your saw's cutting head from staying upright and, as a result, cause a ...
Items 1 - 12 of 268 - $0.00 (0 Item). You have no items in your shopping cart. MyAccount · Login ... Spring for AG 4980SS. 4980-5. $8.53. Spring. 6310-5C. $7.11 ...
Shop for Where can I get a spring... on GoogleRecoil Starter Spring Homeli...$10.00eBaySpring Starter Chainsaw Ech...$4.99eBayHomelite 26lcs, 5?20, 5?30n, 6...$24.00eBayMcculloch Chainsaw Spr...$13.99eBay5x Husqvarna 362, 365, 371...$19.75BonanzaSearch ResultsHow to rewind a pullstart spring - YouTube? 5:05https://www.youtube.com/watch?v=qTcL3_3leTkMar 13, 2010 - Uploaded by lenniepincherIf you ever need to rewind a un coiled pullstart spring. This might help you. It took me ... First pull of my chain ...Chainsaw Rewind Spring Replacement - Echo ... - YouTube? 3:38https://www.youtube.com/watch?v=oqcjL7W0XMAFeb 18, 2013 - Uploaded by RepairClinic.comThis video provides step-by-step instructions for replacing the rewind spring on Echo chainsaws. The most ...
? 8:48
https://www.youtube.com/watch?v=d4r8wbejHXY
Feb 19, 2013 - Uploaded by chaseme81871
Thank you so much! I was able to find the pull cord at a local home depot store and when when my husband ...
? 5:05
If you ever need to rewind a un coiled pullstart spring. ... ( NEW VERSION ) How to Rewind and Replace Recoil Starter Spring - Duration: 3:53.
depends on what machine it is your trying to fit the rope to!! some you have to take off the spring tension and remove the pulley in order to feed the rope into and put knot on bottom of pulley, however most briggs and stratton and honda recoil starters you can pull the rope completely out and remove rope then fit new rpe and let spring pull it back in
First remove the pull starter housing.
The next part is tricky. You'll have to release and unwind the spring that rewinds the pull starter cord. Remember how you do this because after replacing the cord, you'll have to rewind the cord and spring before inserting it back in the housing.
re-attach the pull cord housing to the chain saw.
Hope this helps.
There are special tools made for this job, however not needed for most jobs (makes easier). Clean the spring and lube slightly with silicone spray or light oil. Catch the end of the spring that would be the outer end onto slot or pin and slowly spiral the coil into place holding down coils as you turn(dont try to coil the spring then drop it in, take your time as you wind and maybe ask a freind to lend a third hand if your fingers get tired, once you start you cant stop). The inner part of the coil has a bent hook that will catch on the inner portion of the pull rewind. Lood at how the rewind catches this hook by turning the rewind in the direction that it turns when you pull the rope. When you pull the rope it winds the spring. If you put the spring in backwards the rewind spring will not catch. Once you got the spring in place, turn the rewind in the direction that it turns when you pull the rope until it stops, then release one turn and insert rope thru guide and into spool to tie knot. Slowly let rewing pull in new rope. Good luck
The cord should be removed from the spool entirely, then wind the spool spring CCW for a number of turns making sure the spool can be turned for about 6 turns more (during start). Wedge the spool so that it can't unwind the spring again. If the old cord was about worn out, replace it with fresh. Melt the cord end somewhat so that the knot won't pull out, then tie an overhand knot in the cord end. Feed it into the inner retainer on the spool, then thread the cord around the spool 5 or 6 times in a CCW direction. Once wound, feed the loose end out of the cord port, slide the pull handle on, melt the cord end, and tie an overhand knot on it. Stuff the knot into the handle and release the wedge from the spool so that spring tension pulls the cord tight. Pull the cord out several times to make sure nothing interferes with cord and mechanism, then install on the saw and check the start operation. The spring should never bind-up when the cord is fully extended. Hope this helps!
It sounds like you did not properly rewind the spring that is behind the spool that the cord would around, that spring is what rewinds the cord after pulling the cord.
You will need to take the housing off to expose the rewind mechanism. The most likely cause will be a broken rewind spring. Go on the WEB and search for your model and a part list. Locate the spring and order it. Once you install the spring, you will need to pre-tension the spring by by pulling the cord part way out and ciol it on the spool. Good luck
